D17 Power steering issue |
CTALLIS ![]() Orange Level ![]() ![]() Joined: 22 Nov 2010 Location: Northfield Points: 619 |
![]() ![]() ![]() ![]() ![]() Posted: 12 May 2025 at 3:34pm |
Have a D17 Series 2.
Power steering not working as it should. Sometimes it steers like a mule to the left, other times its ok. The fluid foams and if I try to fill it it comes out the breather. put 5w 20 oil in it. any help would be great. thank you
AC720Man ![]() Orange Level ![]() ![]() Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5147 |
Wide front or narrow front? I run 821 Hydraulic oil in my series 1 narrow front. I would drain the system and replace the oil if you haven't already done so. Fill only to cover the gears, you may be over filling it? Check the breather and make sure it is clean so it functions properly.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21426 |
5W-20 is engine oil, correct ??? Engine oil could have a foaming effect that the proper type of HYDRAULIC oil doesn't have. Has the problem surfaced when changing to this 5W-20 oil?? if so, drain it and get Hytran/HyGard or AGCO 821 oil in there and just cover the gears with fluid. Any fuller than that and it will vomit out the excess.
Edited by DrAllis - 21 hours 10 minutes ago at 3:51am |
thanks I'll give that a try
You didn't answer the million dollar question: did this problem surface after changing to 5W-20 oil or not ??
it was doing it before I change the fluid.
thought flushing it out and adding new fluid might help.
I have 821 hydraulic fluid in my D14 and D17. Has worked well for me. There are pockets in the front support that won’t drain initially so you may have to change it twice after you run it some to get the engine oil out of it. That should solve your problem. Do not overfill as I said above as well as Dr Allis.
If it was doing it before, then I'd say you may have pump troubles. It could be sucking air in thru the input shaft seal(s) causing the oil to foam when it isn't OVERFULL before start-up and sitting on the level. I'm assuming you have the pump under the distributor?? or the belt driven newer style on the generator side ??
Alex09(WI) ![]() Orange Level ![]() ![]() Joined: 15 Mar 2012 Location: CECIL WI Points: 1726 |
In my experience, any time the power steering oil foams, it is the pump shaft seal sucking air.
www.awtractor.com
