7045 spindles
Carl(NWWI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Topic: 7045 spindles
    Posted: 04 Jan 2011 at 3:22pm
anyone ever taken the spindles off of a 7000 series. What holds the spindle tight against the arm, ours has a 1/4 inch gap between the snap ring and arm. Is there any trick to getting the arm off the spindle, or just hit the top of the spindle with a maul?
Thanks, Carl
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2011 at 3:57pm
Carl - is the arm keyed into the spindle?  If so you have to pull the arm up and can't beat the spindle down through the front tubes since the key will gouge into the tubes and stop you.  I know they are that way on earlier tractors.  Probably need to heat the arm up with a rosebud and put a good puller on it.   Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2011 at 4:16pm
yes, it is keyed, i read in the I&T manual that you have to cut the arm off the spindle with a torch, seems like a big waste to me, not only of a good arm, but money, cuz im sure new ones arent cheap. things like that make me want to get the person who designed it, and have him do it. He'll see how fun it is. lol
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2011 at 4:29pm
We used a three jaw puller on em, gotta heat em red hot, kinka takes the goodie out of the puller jaws cause they are tight!!!  Might halfta heat em again to get them to slide back on the spindle!! HTH
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2011 at 9:11am
Lonn posted how they did it at the dealer he worked for.It went something like this...cherry up with rosebud and quench with 5 gal bucket of water....should slide right off....install-cherry up with rosebud ,drop in place ,let cool on its own...will stay tight.I need to replace bushings on a 8070 but feel leary also.
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2011 at 10:14am
You might have to grind off some around the snap ring area,if its peened even a couple thousanth it won't come off,BTDT!!
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2011 at 10:19am
Here it is again
Listen to me if want it to be tight again when you put it together. Get a 5 gallon pail of cold water. Heat the arm with a rosebud until it is red hot all around the spindle shaft. Pour the water over the arm to cool it quickly. Now you should be able to easily pull it or tap it off. When you go to put it back on heat the arm again to red hot. Slide it on the arm. Don't forget the half moon key. Let it cool on it's own. Works every time and it will be tight and not come loose like I have seen some do. That's how we did it at the Allis dealer I used to work at.
If you press or pull it off and then back on without heat you can run into problems later and it's a lot more work.
Wink
I am a Russian Bot
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2011 at 10:20am
Remember to remove the wheel as has been mentioned before
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2011 at 2:31pm
alright, thanks alot, I'll give it a try when i get a chance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2011 at 5:27pm
I can't figure out why you're worried about 1/4" inch gap between the snap ring and the arm????  Many of them look like that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2011 at 5:49pm
well this is the only one we've had or worked on. always had IH. and i was just curious on why there was a 1/4 gap there. cuz i would seem like it would just fall down and be loose, but now i know why. Thanks to the above ppl
This page was generated in 0.211 seconds.
