H3 Steering Clutch |
Pgriswd
Joined: 25 Mar 2025 Location: South Carolina Points: 26 |
Topic: H3 Steering ClutchPosted: 28 Apr 2025 at 7:30pm |
I rebuilt the steering clutches on my H3 and reassembling. Right side went together like a champ. The left side though is almost back together but the drive spline will not slip into the clutch. Using bore scope, it looks like the splines line up with the clutch on the top, but on the bottom, the splines are not lining up and won’t slip in…I am at a loss…any suggestions?
Edited by Pgriswd - 28 Apr 2025 at 7:41pm |
Les Kerf
Posted: 29 Apr 2025 at 8:37pm |
Do you have any way of posting pictures of the view through the bore scope?
Pgriswd
Posted: 30 Apr 2025 at 2:57pm |
Pgriswd
Posted: 30 Apr 2025 at 2:58pm |
Pgriswd
Posted: 30 Apr 2025 at 3:00pm |
I removed both clutch packs and found the splines are different, so I guess there is a left and right side and I put them in backwards. I haven't reinstalled but I think that is the issue - the drive spline and clutch packs are matched.
Pgriswd
Posted: 30 Apr 2025 at 3:08pm |
Pgriswd
Posted: 30 Apr 2025 at 3:09pm |
Pgriswd
I think you can see the difference in the two packs
Les Kerf
Posted: 02 May 2025 at 7:54am |
The distortion of the photos makes it a bit difficult to tell for certain, but it appears that the the splines actually vary in width. Is this correct? Thanks for the feedback
Pgriswd
Posted: 03 May 2025 at 4:49pm |
They are but it looks like wear
I swapped the left and right. The right went in and the left is still not fitting |
Les Kerf
Posted: 07 May 2025 at 9:32am |
Any progress? I downloaded an H3 Service Manual, it isn't very clear; are the shafts reversible? ![]() |
Pgriswd
Thanks(1)
Posted: 07 May 2025 at 3:30pm |
I took the clutch apart and worked with only the hud and shaft so I could see. Once the hub is bolted up to the flange, the shaft is out of line with the hub..not much nut just enough that the shaft won’t insert. Not sure how that happened but probably explains the wear on the hub. I am thinking on shim the clutch on the flange to fix the alignment issue. Will try to post pics.
Pgriswd
Thanks(1)
Posted: 12 May 2025 at 7:26am |
Hello all
Thanks for the advice and I got it in. Still not sure why there is a mis-alignment. Just need to decide if I want to shim or just bolt it up. I guess it’s been bolted up that way for 60 years. |
Les Kerf
Posted: 13 May 2025 at 2:49pm |
Glad you got it back together and thanks for the feedback
