ED 40
Orangenubbe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orangenubbe Quote  Post ReplyReply Direct Link To This Post Topic: ED 40
    Posted: 28 Oct 2024 at 5:25pm
Greetings from the Shenandoah Valley of Virginia. I am new to the forum and wanted to post my most recent purchase to share. An ED 40 that spent most of it's life at the Homestead Resort pulling a finish mower. It runs and seems like a solid candidate for a resto.I hope to learn all I can from you folks about this model farm tractor. I've included a picture.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2024 at 6:15pm
Welcome. It's nice to find a complete running ED40 Those have some unique problems that some that have them can help you with.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2024 at 7:22pm
Yeah, IIRR, the most common major problem is that something in the lift breaks a casting...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orangenubbe Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2024 at 6:06pm
Thanks for the heads up on the casting issue. Right now, I need to replace a steel hydraulic line before I can start it.
It is missing all the 3 pt. hitch equipment. I hope that's not a bad sign of things to come. No draw bar either.
The exhaust is also missing. Just the down pipe from the manifold.
I don't have big plans for the tractor. Maybe pull a mower once in a while. Parades and Steam and Gas shows. Something to tinker with in retirement.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2024 at 9:17pm
Welcome to the forum. Is this your first allis tractor.
Which line do you need. Do you have parts book and manuals.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orangenubbe Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2024 at 2:49pm
Hello. The steel line runs under the fuel cell, down the top of the trans and seat. It’s rusted from rodent urine I guess. Easy fix. I can make one.
I do not have any manuals yet.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2024 at 6:58pm
DanielW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanielW Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2024 at 6:54am
I always liked the ED40. Pretty robust units. There are a lot more of them here in Canada than there were in the US (like a lot of other British-built tractors, and the British-built AC square balers). Biggest issue I know of is them being very grumpy starters - especially in cold weather. I can't remember the details, but there were some glow-plugs that were used on a model of Nissan diesel that are apparently an easy retrofit into that engine, and make for much easier starting. Some of the Massey 35's had that same engine, made by the Standard Engine Company.
Edited by DanielW - 31 Oct 2024 at 7:21am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orangenubbe Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2024 at 7:06am
Hello Daniel, Grumpy starters are no fun. Thanks for the info. I have UK ancestry so it seemed like a good project. hahaha
 Once I get a manual for this rig, I hope I can figure out the different controls in the instrument panel. I think I read that it has glow plugs. All the labels are sun baked so bad that you can't read them. Oh well, all part of the project.
Hover26 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hover26 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2025 at 9:35am
Did you have any luck getting a service manual I need to know how to time the injector pump
John426 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John426 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2025 at 9:53am
Hi
I never heard that there is a service manuel for the ED 40. There is Parts manual and operator.
For the Engine it is the Standard 23C , same than Ferguson 35 ( 835) also John Deer model 303 and 505 ( 303 and 505 are French designation , don't know if it is the same in America) and Leyland too
So you can get service manual for these Tractor, same injection timing.
The time is 13° advance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orangenubbe Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2025 at 4:35pm
I finally found a parts book. Very helpful.
I also sourced 3 of the 4 lift arm parts. Still need the Left side link rod.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2025 at 8:16am
Hi Colin
What’s the part number of link you need
Post Options Post Options   Thanks (0) Thanks(0)   Quote John426 Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2025 at 11:56am
Hi Hover26
This is the workshop manual for Massey Ferguson 35 , MF35.
I can't upload it on the forum , it is too large file. But you can download from scribd website
inside you will find all informations about the engine Standard 23C, the same you have on your ED40.
Be careful, after use. Often, and based on my experience, the preferred injection timing  angle is 16° and even 19° instead of the recommended 13°.
This is due to wear on the drive chain.
Sherman Farms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sherman Farms Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2025 at 2:20pm
I have three Ed-40s and would be willing to sell two of them, if anyone is interested let me know,
B, C, RC, 3 wc,2 wd,3 wd45, d15, d17, d19, d21, 190, 440, 7040, 918 backhoe, 12 roto balers, 7 60 combines, 40, 66,2 72,90 super, sp100, Gleaner E, F3, 3 L2, R62, and much more
This page was generated in 0.239 seconds.
