Allis B for cultivating
KouryFarms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KouryFarms Quote  Post ReplyReply Direct Link To This Post Topic: Allis B for cultivating
    Posted: 19 Apr 2025 at 6:38am
I’m looking to buy a small tractor for my market garden to belly mount cultivators. A friend has a Farmall cub and suggested I try finding one but the allis b keeps grabbing my attention instead. My question is, how is the visibility from the driver’s seat ? I know the Farmall is offset. Is the wide double seat on the allis better? Or at least comparable? Other option would be to find a g model but like the versatility of a b model better. Thanks, George
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2025 at 7:19am
When I was young I cultivated a lot of corn with a B and it did a pretty decent job.Couple of negatives is as you said the visibility factor and 1st gear is too fast especially very small plants.A G is pretty good if it has the extra low gear.The Farmalls are very good because of the visibilty and there are a huge number of accessories available like side dressers,planters,etc.For cultivating I now use a Hines H-1600 which is the best tractor I have ever used to cultivate vegetable type crops,its very much like a G but much improved.It has hydrostatic drive,hydraulic lift with different controls for front and back.The implements go on and off quickly,very comforatable to get on and off,uses 24 inch rear tires.The Tuff Bilt tractors sold now are basically a clone of the Hines.
jvin248 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2025 at 7:53pm
Gs and Cubs tend to be expensive, Bs are cheap and plentiful.
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2025 at 8:18pm
Go look at all 3 if you can. Everything about a G is spendy. But B's can be tough to get on and off of. As said lots of B's around and much cheaper. I think most G's have the creeper gear. Hey just a thought buy a couple. That's what most of us end up doing
Post Options Post Options   Thanks (0) Thanks(0)   Quote KouryFarms Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2025 at 8:25pm
Thank you for the great info. The creeper gear on the g is an interesting topic.
I certainly wouldn’t mind owning one of each ! …
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2025 at 9:22pm
Originally posted by mdm1 mdm1 wrote:
... But B's can be tough to get on and off of...
Amen to that! Big smile
Those of us who are pushing 70 have to think about whether or not we really NEED to get on that tractor. My 14 year old grandson bounces on and off my Model C like a monkey. Ah, those were the days Tongue
wade89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wade89 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2025 at 10:03pm
I cultivated a couple acres of potatoes with a B. You can make most any type of shovel, spring tooth or finger weeder work on the factory cultivator. I even had the hiller
discs from China mounted to it. Only issue I had was it bein pretty fast in 1st. Maybe shorter tires would’ve helped? If you hold out for a CA, it’ll have a 4 speed and be 1/2 mph slower in low gear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KouryFarms Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2025 at 6:12am
I’d like to try adding the newer Timor cultivating equipment to the older tractor.
Appreciate having ground speeds pointed out. My farm is mostly short rows. Too fast in 1st and I’ll run out of row before I even begin.
Ground speeds from the Nebraska tests:
B in 1st is 2.50 mph
G in 1st 2.25 mph
G in special low 1.6 mph
CA in 1st is 2.0 mph
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2025 at 6:44am
If your rows are that short you might want to look into some of the really good walk behind garden tractors built by AC/Simplicity over the years
dkattau View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dkattau Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2025 at 7:04am
I cultivate two rows at a time in the garden with my CA. It has enough hp that I can throttle way back to what I’m guessing is less than 1.5 mph.
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2025 at 8:24am
I'd point out that most Bs have the standard wide front end, which isn't adjustable other than being able to flip the offset of the wheel disk around on the hub. There are some out there with the optional adjustable wide front end, though.
What sort of spacing between rows are you planning to cultivate?
Post Options Post Options   Thanks (0) Thanks(0)   Quote wade89 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2025 at 8:39am
Another consideration is any other equipment you’re using. For example, my B was used for a one row potato planter and a one row picker that both started life horse drawn. The rows were wider back then as they didn’t irrigate or fertilize and I was able to guess approximate yields and planting rates off historical U of M articles. Grew them that way as they were “close to organic” and had people lined up to sell direct out of the ground as fast as I dug them.
However my green beans I use a narrow front CA with a different amalgamation of equipment.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2025 at 2:05pm
George, first off “welcome to the Forum.” You can get lots of great information here and probably a bit of bull also. Both the B and the G are great tractors but for me the B is a lot more versatile, just not as good at cultivating. I grew up on a B and WD and still have a B (not running right now) with a few odds and ends. I’m probably not too far from you, off US129 between Athens and Jefferson..
Joe M up in Cumming is the G expert. Super great guy and very knowledgeable. If he sees your post I am sure he will chime in.
thendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2025 at 2:21pm
Welcome from another Georgian. I'm in Fairmont. You might also look into a tuffbilt or Thomas built as they started out. They're basically a G with hydrostatic drive. I think they're what became the Timore. I believe a Hines was mentioned earlier, it's basically the same thing. The tuffbilt maybe a little more rudimentary then the Hines or the G. I have a tuffbilt but mine is not as easy to get on and off as it could be
Edited by thendrix - 20 Apr 2025 at 2:23pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2025 at 3:20pm
I have a long narrow garden patch. What I've done is angle the rows like herringbone parking lot lanes. That way I can stretch individual rows out to as long as I want and still have a lot of individual rows: /////////// instead of llllllllll. Might help you with longer cultivating runs.
You might tune the B down to idle super low on low gear if that base gear is too fast.
Edited by jvin248 - 20 Apr 2025 at 3:23pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote KouryFarms Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2025 at 5:04pm
A friend invited me to the Double H Farm show in Cleveland Ga this May. Maybe I’ll get lucky and see a few different models in person
Post Options Post Options   Thanks (0) Thanks(0)   Quote KouryFarms Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2025 at 5:38pm
This is a good idea, my current rows are around 50ft in length. If I clear a new area might be able to push to 100-150ft on the diagonal.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2025 at 5:32am
My garden is 45'X110' roughly, measured it the other day. I plant the short ways. That makes it easier to move the sweetcorn from one area to another over the years. Seems to keep the rootworm under control.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KouryFarms Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2025 at 10:15pm
I’m using a small LS tractor. Outside wheelbase is 69 inches, 33 inches between tires. Tires leave 18inch wide track that I use as walkways. Rows are 33 inches wide, also using pto tiller of same width along with few other small implements.
This page was generated in 0.238 seconds.
