Eaton 2-Speed ??? |
BuckSkin
Joined: 12 Sep 2019 Location: Poor Farm Points: 1187 |
Topic: Eaton 2-Speed ???Posted: 16 Apr 2025 at 10:22pm |
Sunday_13-April-2025 Greg's New C-65 Chevrolet - --- - ![]() - --- - ![]() 1975 w/427 and Air-Brakes ![]() ![]() Please take note of the shifter-pole and the gear knob. Of all the many trucks I have driven, I have never before seen an Eaton 2-Speed. The engine is a Big Block 427 Gasoline The bell-housing and transmission are HUGE. ![]() ![]() Can anyone please tell us just what we have here as neither of us have ever seen one before. If the pole is "five-speed" and then split, one would think it a 10-speed; however, every Eaton 10-speed I have ever driven (I hate them, by the way) has the T-handle range selector clamped on the pole and no button on the knob. What do we have here ? Thanks.
Edited by BuckSkin - 19 Apr 2025 at 10:39pm |
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35731 |
Thanks(1)
Posted: 17 Apr 2025 at 4:01am |
The truck had been a Tandem at one time, had TWO Eaton Two Speed differentials shifted with Air not Vacuum or Electric, where in the 1970s there was a Attempt to make the two Individually capable of being shifted independently, IE Eaton Three Speed Rears. Heavier gear box and bell housing was for that tandem load rate.
BTW Ford Super Duty 750/850 series were well known for the three speed setup, converted a great many to two speed control. As a Add, 90% of all the HD Road Trucks had Eaton Fuller 8, 9, 10, 13 or 18 speed transmissions. Learned to drive those in Freightliner Cabover with a 13. Easy as Pie.
Edited by DMiller - 17 Apr 2025 at 4:03am |
Codger
Thanks(1)
Posted: 17 Apr 2025 at 6:15am |
Seen that setup on a couple of GM, and Ford products back in those days. Never did like it myself as when one shift set was worn, something got into a bind, (think driving two rear axles at different ratios) the result was usually destructive to drivelines. Usually behind a "Spicer" five speed transmission. Never seen the setup in diesel; always gasoline powered units being usually fertilizer, or fuel delivery trucks.
That's All Folks!
Lars(wi)
Joined: 14 Sep 2009 Location: Permian Basin Points: 8409 |
Thanks(2)
Posted: 17 Apr 2025 at 6:58am |
Best thing to do is, crawl under the truck and read the model number on the side of the transmission, then you know for sure what it is.
I myself, have operated a plethora of Eaton transmissions over the years, straight 5, 6, 7, 5+2, 8, 9, 10(the most common at the time), 13, 18(one my fav), and the Super 10. The worst is the Eaton Auto-Shift, absolutely miserable to use. Edited by Lars(wi) - 17 Apr 2025 at 6:59am |
Thanks(1)
Posted: 17 Apr 2025 at 7:12pm |
Now Eaton Three-speed Axles | 6th November 1964 | The Commercial Motor Archive
The Origination that failed and went to Two Speeds only. |
Codger
Thanks(1)
Posted: 17 Apr 2025 at 7:47pm |
Those worked well; for a while till the wear set in and as mentioned, catastrophic failure. Usually replaced by two speed axles, or a 10 speed trans and single speed rears.
That's All Folks!
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4079 |
Thanks(1)
Posted: 17 Apr 2025 at 8:02pm |
looks like its missing some real importent parts
BuckSkin
Posted: 17 Apr 2025 at 8:16pm |
Them necessary pieces not shown in the photo are piled up on the other side of I guess that thing is a pontoon boat.
BuckSkin
Posted: 17 Apr 2025 at 8:19pm |
Do any of you guys know that truck ?
It belonged to Fritz's Garage and Towing of Lorain, Ohio; it had a huge wrecker bed with four big winches.
Codger
Thanks(1)
Posted: 17 Apr 2025 at 8:39pm |
Don't know the truck at all but in those days there weren't that many diesel trucks in medium duty service.
That's All Folks!
Thanks(1)
Posted: 18 Apr 2025 at 2:42am |
As Codger noted most of those days were Gas, 429 & 534 Ford, 366 & 427 GM, 504 & 549 IH, Dodge had the Industrial Hemis’. Massive Gas swillers.
DaveKamp
Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6126 |
Thanks(2)
Posted: 18 Apr 2025 at 9:34pm |
Don't forget the GMC 478 V6...
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5282 |
Thanks(2)
Posted: 19 Apr 2025 at 4:00am |
Or the GMC V12 gas truck engines. Hyattstown, MD. purchased 3 early 60s tilt cab trucks, 2 pumpers and a HD rescue when the new interstate was built north out of Washington DC. With their station located right at the end of an exit ramp, those 3 new trucks had specifications to be able to reach and maintain at least 100MPH even in the grades. Fuel mileage wasn't even an issue. Gas at that time was under $ .25 a gallon and those trucks had 2, 50 gallon tanks.
Thanks(1)
Posted: 20 Apr 2025 at 7:33am |
GM V6s were a Major PITA to work on, the 12s just added a second engine to that forest fire. Spark Plugs in Engine Valley, shorter ignition circuits but also legendary garbage trough for debris to fall into opened holes and corrosion around plug threads. Mice and other rodents built nests like Ft Knox as those sat starting lots of fires. Could not keep Exhaust Manifolds on them for long.
1951WDNWWI
Bronze Level Access
Joined: 11 Jul 2011 Location: NW Wisconsin Points: 127 |
Posted: 22 Apr 2025 at 6:45pm |
Grew up in northern Wisconsin. What make was the two speed rear end on all those school buses?
Posted: 24 Apr 2025 at 3:45am |
Were only ever two major manufacturers US, Eaton and Spicer while GM constructed their own Corporate Axle in the 50s-70s, parts for those is rapidly attaining Unobtanium. Spicer owns Dana currently as Eaton Fuller owns several previous lines. Not many if any Two Speed differentials anymore with decreasing Gas Engine options, deeper torque curve diesels and Auto or semi-auto transmissions no longer a need.
Codger
Thanks(1)
Posted: 24 Apr 2025 at 7:28am |
Both of those brands are really the only ones that were common in the trucking arena. Bendix-Westinghouse used to market some also but I think they were actually Eaton design. Haven't seen a truck newer than early 80's that had a two speed axle myself although have seen some Rockwell, (Meritor) two speed axles in tandem setup for heavy haul work. Durability always depended upon the driver/operator. Lot's of problems with these with slip seat type operation where they did very well with a single operator.
That's All Folks!
