Compression
Stoges View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stoges Quote  Post ReplyReply Direct Link To This Post Topic: Compression
    Posted: 16 Apr 2025 at 6:36pm
Some where I saw someone running 240psi compression in a WD45, isn’t that a bit too much.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2025 at 7:56pm
My D-17 puller had 300 psi. It required 114 octane fuel.  240 psi works well with 110 octane.
ekjdm14 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ekjdm14 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2025 at 1:02pm
300psi wow, surprised we're talking octane and not cetane at those numbers LOL
Sure it'd run somewhat OK on diesel with 300psi, must be a real ripper on gas when she gets on song!
Stuck Farmer
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2025 at 8:12pm
Wow for sure! How did you get them to turn over when starting?
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2025 at 11:41am
My local alternator/generator/starter shop (which there are very few left these days) installed some stronger field windings on my D-17 engine, which was already 12 volts. I used an 880 CCA battery and welding cable for my battery cables. My WD was just a stock 6V Delco starter with a center bearing in it, and again an 880 CCA batt and welding cables.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2025 at 12:01pm
Thank you. Very interesting thread. I did not know you could get that much compression in a gasser. 😀😀
This page was generated in 0.223 seconds.
