AC 175D wiring?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: AC 175D wiring?
    Posted: 13 Apr 2025 at 10:22pm
I have a 175D with a bad key switch. A couple of the spade lugs are rusted off and wires hanging. Is there a better wiring diagram of the wiring than the one in operators manual. Thanks, Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2025 at 9:14am
You should be able to trace the wires to where they go. The "on" position should go to the push button switch. The "start" position is for the manifold heater. The last one would be the power that goes into the switch.
Edited by DSeries4 - 14 Apr 2025 at 9:14am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Apr 2025 at 10:39pm
I got it going after work. Thanks Joe M for the wiring diagram. It was just the ticket. Had to replace key switch and light switch. A good day for once! Thanks, Tracy
