Allis Chambers All crop 60 combine wheel hu
Allis 1952 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis 1952 Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chambers All crop 60 combine wheel hu
    Posted: 31 Mar 2025 at 6:22pm
Would anyone have a Allis Chambers all crop 60 wheel hub dust bushing cover
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2025 at 8:26pm
Is that the same as an Allis Chalmers all crop 60??? Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2025 at 8:52pm
This what your looking for
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis 1952 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2025 at 2:51pm
Mine is round and a little flatter I tried to copy the picture but it won’t let me my hub is all crop 60 of a pull type combine
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2025 at 3:22pm
does it pilot into a bore like a trailer grease cap, or bolt on like the above photo ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis 1952 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2025 at 3:31pm
It bolts 4 bolts like the orange one but mine is round and a little flatter
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis 1952 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2025 at 3:33pm
And the grease fitting lines up with a hole in the hub that grease the bushings in the hub the hub has brass bushings no bearings
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis 1952 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2025 at 3:51pm
I tried to put my picture on here of the cover of the hub but this forum says it’s to big
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2025 at 3:56pm
Most cameras take 4000 x 3000 pixel photos or bigger... Open the picture in PAINT or other program on your computer and RESIZE to 800 x 600 ..... if your using a phone i think you can e-mail the photo to yourself, and then RESIZE..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis 1952 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2025 at 4:02pm
What is your email address I will send the pic to you
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2025 at 4:36pm
Robert
Is yours like this one in the attached Video ?
   L/H Wheel at 2:55 minute Mark for L/H wheel, no sprocket
   R/H wheel at 5:48 with Reel Drive sprocket
https://www.youtube.com/watch?v=KinOqKfCuno
     Hey Stevie
     Do you really think he could make one of your suggested
        Dexter Trailer Hub Caps work?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis 1952 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2025 at 4:58pm
My cap is flatter and and the grease fitting is in a different position because it Carries grease all the way through the hub question did the 66 have bearings or bushings for the the axle in the hub
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis 1952 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2025 at 5:21pm
That hub looks like hub I don’t need the gear really need the other wheel cover
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2025 at 7:08pm
So Robert, when you say "that hub" are you referring to the L/H Hub in the Video?
G
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2025 at 7:12pm
Parts book lists different ones per your serial number.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis 1952 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2025 at 8:04pm
I don’t know the serial number it’s long gone
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2025 at 10:47pm
You can email pictures to
Michaelzakens@gmail.com
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2025 at 11:20pm
Maybe this site might help…
https://allcropharvester.com/
dkattau View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dkattau Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2025 at 2:34am
What’s your serial number? It’s stamped into the frame below the LH cylinder bearing.
Edited by dkattau - 02 Apr 2025 at 2:36am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2025 at 9:57am
Pictures of what he has.
Someone must have done a farmer fix sometime in its life. Correct me if I’m wrong but this isn’t allis right.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis 1952 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2025 at 10:32am
It was a all crop allis Dad bought 2 back in the 70s one good one and one for parts but it’s all Allis Chambers the diagram you sent me is what it had on it but over the years the cap was took off and don’t know where it went
