M2 Exhaust Manifold
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Topic: M2 Exhaust Manifold
    Posted: 04 Jan 2011 at 11:48am
I was combining corn last night and when I went to start the combine this morning found the exhaust manifold cracked on the port closest to the flywheel end of the engine.  Is this common?  What should I look for that may have caused this, is there a clamp or support that could be broke or missing?  Where would I find a used manifold?
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2011 at 1:49pm
Well,I was bush hoggin with my uncle's 7020 (same manifold) and stopped for supper.Hadn't been working it hard at all (pasture) so I just throttled it down for a bit then shut if off and started walking accross the way to the house.I got about 30ft away an BANG!!! WTF!! Went back for a look and the manifold was broke btween the back and middle ports. Probably what happened to yours in some fashion. Heat/cool,odd shapes....stress point waiting to happen.
Russ-neia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ-neia Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2011 at 2:41pm
Nothing unusual.  Just heating/cooling for too many years.  Not too expensive from AGCO dealer or aftermarket.  I wouldn't fool with trying to take a used one off and then put it back on and hoping it doesn't already have a small crack.  Your labor will cost more than just using a new one to begin with.
The innovators offer what others will imitate.
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2011 at 6:26pm
Thanks.  I have found a new one for what I was hoping I could find a good used one for.  They even have one in stock (that about told me it was a fairly common problem).
