Hydrovac brake booster |
darrel in ND ![]() Orange Level ![]() ![]() Joined: 22 Nov 2009 Location: Hebron, ND Points: 8728 |
![]() ![]() ![]() ![]() ![]() Posted: 24 Mar 2025 at 8:13pm |
I'm thinking about buying a 74 chevy truck that I found for sale. Just seen pictures of it, haven't looked at it in person, or even talked to the seller. But one of the items in the description states that it needs a new hydrovac brake booster. Where is a good source for a new one of them, and what would a person expect to pay for one. Thanks, Darrel
Gary ![]() Orange Level Access ![]() Joined: 13 Sep 2009 Location: Peterborough,On Points: 5903 |
This link might help you some: https://www.youtube.com/results? search_query=1974+chevy+hydro+vac+brake+booster+replacement |
wjohn ![]() Orange Level ![]() ![]() Joined: 19 Jan 2010 Location: KS Points: 2256 |
I just bought a '62 C60 and you have to pump the pedal a lot, and the engine revs way up, so I suspect the booster is about toast. Might not be the exact same part number but I think both trucks are in the same boat as far as parts availability.
Looking around online, I had found one place that would rebuild them, and another place that would sell you a kit to convert to something like an F-550 brake booster and master cylinder that mounted on the firewall. Both paths were $5-700 as I recall. Knowing what I know now I would definitely factor that into any offer I made on the truck. EDIT: I stand corrected - looks like these are able to be ordered through most auto parts stores, but you may need a guy behind the counter that knows what he's doing. The model/year lookup doesn't work for many of these older medium-duty truck parts.
Edited by wjohn - 26 Mar 2025 at 6:15pm |
HudCo ![]() Orange Level ![]() ![]() Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3941 |
must be 454 is it leaking ?
DMiller ![]() Orange Level Access ![]() Joined: 14 Sep 2009 Location: Hermann, Mo Points: 34277 |
Friend of mine has a failed Hydrovac, is on his Dad’s old IH Farm truck, bought new in 63. He has gone every route of phone calls and in person contacts found nothing. Thought should be some New old Stock laying around for diaphragms and seals, nothing. Last known rebuilder near to here closed shop several years ago.
8070nc ![]() Orange Level Access ![]() Joined: 21 Mar 2019 Location: North Carolina Points: 637 |
I just got one from carquest. I would think napa would have one.
1984 80780
It was for a 87 ton truck. Yor 74 is the same basic body style
1984 80780
I think that I have one located. Thanks for the replies.
Darrel |
DaveKamp ![]() Orange Level Access ![]() ![]() Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6087 |
So... Just for those who don't know... in power brakes, there's Hydrovac, and Hydrobooster. Two different systems, commonly confusing to those who don't realize... The Hydrobooster is a brake booster that, instead of using manifold vacuum to assist the brake pedal's actuation of master cylinder, it uses hydraulic pressure from the power steering pump, or a secondary equivalent. My '84 Grumman (Chevy P30) step-van uses a hydrobooster, because the firewall shape doesn't have space for a conventional vacuum booster AND.. it's original engine was a 6.2L diesel... then a 3.9L Cummins 4BT, now a Buick 455... The HydroVac was pretty common on Chrysler/Dodge medium trucks and RVs... they're essentially same as a vacuum power brake system, but the common vacuum-power brake system integrates the master cylinder WITH the booster diaphragm/chamber. A HydroVac is actually separate from the master cylinder... it works exactly the same way, but the physical link between the foot pedal/master cylinder doesn't exist, it's all result of the master cylinder's outlet pressure triggering the HydroVac.
Most mounted behind the Left Cab Step(Extended below cab), many were crud traps and damage occurred when not kept clean. Best laugh I got from a Brake system, I had Changed a Hydrovac on a Old IH as noted above, old guy was tickled got it back(Decades ago) as needed it to run grain harvest to elevator. Came strolling in, "It's Brake AGAIN" and beet red, walked out to truck stepped on brake sure enough little boost, but Also Muffled Sound of Vacuum relieving. Folded bench seat forward, removed the Coveralls sucked up tight to the Vacuum Vent in the floor behind the seat. All Was again Right in the World, Ed turned Beet Red of Embarrassment at that point. NO Charge!!
LouSWPA ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Clinton, Pa Points: 25290 |
fwiw, MY experience with those Hydro boost systems was with fleet cars. The company vehicles we had when new were problematic. Just antidotal to be sure but we had higher than normal failures as compared to the older cars w/o
I am still confident of this;
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8662 |
73 C60. Mine was rebuilt by Cardone. None in stock for exchange....send it in.
KJCHRIS ![]() Orange Level ![]() ![]() Joined: 21 Dec 2015 Location: WC Iowa Points: 966 |
Haven't replaced a hydro-vac brake unit in 20+ years.
BUT see if you can locate an older truck shop that has a "pressurized brake bleeder" that attaches to your brake master cylinder. It'll make getting air pushed out of the system lots easier. Might want to try pressure bleeding existing unit before replacing it, may have an airlock from sitting. IF can't find 1, follow directions that come with the replacement unit.
NAPA, O'Rielly, Inland Truck Parts, MidWest Wheel Co., Vander Haag's, are some places to check for a rebuilt unit. |
Codger ![]() Orange Level ![]() ![]() Joined: 23 Dec 2020 Location: Utopia Points: 2458 |
Not a hard thing to rebuild at all. Just another type of hydraulic master cylinder, and a lot simpler than most believe. I've rebuilt several over the years.
Just another thing my wife loves seeing at the kitchen table, or next to the toaster on the counter. Not really but she doesn't get irate till the carburetor cleaner comes out.....
That's All Folks!
desertjoe ![]() Orange Level Access ![]() ![]() Joined: 23 Sep 2013 Location: New mexico Points: 13729 |
I have a 1988 Chevy 1 ton with the 454 that needed the power steering replaced and wound up having to send back the unit they sent three times as the PS required had to have an extra pressure line for the power brake booster. the first item they sent me was A BIG POWER BRAKE BOOSTER unit THAT HAD THE EXTRA piece of the power brake booster ,which we sent back. this was from Oreilly's,,,SO,,it is still available,,,,Good Luck Darrell.
Hey Joe! Good to hear from you. Been a while. Hope all is well for you.
Darrel |
