family d17d sn 4526 |
HudCo ![]() Orange Level ![]() ![]() Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3912 |
![]() ![]() ![]() ![]() ![]() Posted: 16 Mar 2025 at 5:21pm |
brought this tractor after it was sold to a relative about 1988 and then was only used to bale with until the engine went down in 2012 then got tore donwn at a machine shop the place shutdown and the top end got scraped and tractor went back to their shed and sat until two years ago in may and they called me and told me to come get it its your and you are the only one that will do anthing withit i already had all the origial paperwork and reciepts from when it was new
doner engine tractor going out the door but that engingine has blow by so bad it pushes oil out the filler that engine has head bolts mine with the studs sticking up was juast how i got it back so i needed the doner engine for everything from the deck up much more has been done since those photos
uploads/8753/IMG_1049.jpg
sofar no cracks around the valves or ports but it hasnt been magna fluxed yet
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21905 |
Very early ones did not (should have) have a screen.
Allis dave ![]() Orange Level ![]() Joined: 10 May 2012 Location: Northern IN Points: 3050 |
Very nice, YOu've got a 3 spool vavle with it!
the three spool valve came from a parts tractor last fall along with the air cleaner that was missing from mine . was scrapped along with every thing esle from the deck up what does that tube on the pump do it just goes up and points in to the belt pully side and is just a open tube
Provides oil for the front clutch shaft bearing and belt pulley gears especially when the nose is up.
Mikez ![]() Orange Level Access ![]() ![]() Joined: 16 Jan 2013 Location: Usa Points: 8707 |
We just did a bin with a bunch of gaskets if you need any.
