WD45 Fan Belt
Mark (ECIN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark (ECIN) Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Fan Belt
    Posted: 13 Mar 2025 at 4:41pm
I need to change the fan belt on a WD45.  If I take the one bolt out that holds the bracket for the crankshaft (the one you crank the engine to start)....will it give me enough room to get the belt over the bottom pulley?
acd17toy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd17toy Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2025 at 6:38pm
    The only thing you need to do to change the fan belt is remove the lower radiator hose.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2025 at 12:16am
Buy a new piece of hose and cut the old on off. You'll be glad you did.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2025 at 8:35am
Good advice Steve!
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2025 at 11:22am
Good advice Steve!
x3! And unless you know the coolant has been changed, it probably hasn't been done for 50 years so might as well do that too.
Edited by wjohn - 15 Mar 2025 at 11:23am
