8000 roof seal kit
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Topic: 8000 roof seal kit
    Posted: 10 Mar 2025 at 4:39pm
Does anyone have the part number for the foam strips and bolt seals for the top roof panel?  Not sure if the AGCO number includes everything.
Many thanks.
SilverShoes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SilverShoes Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2025 at 6:28pm
Factory seals weren’t worth my time. I siliconed all bolt and edges. No more leaks….Sorry that sounds abit brazen but for as much work went into building the best cab of the day then putting bolts with rubber washers through a flat roof panel. I’ve been down this road replacing all that stuff just for the roof to leak and ruin my nice new interior. Last time I did the roof I siliconed it and I’m not afraid to let it sit in a rain storm now
Edited by SilverShoes - 10 Mar 2025 at 6:36pm
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2025 at 8:58pm
Stainless steel bolts and flat washers. We get the rubber washers from our local hardware store. Do not overtighten. I have not replaced the foam underneath but campershell/bedrail adhesive foam doubled up may work pretty well. Silicone is fine but not reusable like the washers.
I'm lucky enough that all my tractors are under roof most the of the time.
Leon B
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2025 at 9:11pm
Go to hardware store for your foam strip. I paid plenty from AGCO to find it's nothing special. Silicone the bolts/washers....
Tenn allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tenn allis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2025 at 7:30am
Also apply anti-seize to the bolts I have had the bolts twist off while trying to remove the top because the rubber around the bolts will deteriorate
Northern Hoser View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Northern Hoser Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2025 at 12:41pm
This worked for me as well, can't recall the thickness but you'll need two different thicknesses for the sides and the front and back, adhesive on one side not both
I ran a bead of silicone along the outside edge of the foam as well to create a bit of a "ramp" to keep the water back, so far no leaks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2025 at 4:10pm
The roof doesn't leak. It's got an amber beacon on top that I want to remove.
I used the kit from AGCO on my 6080 around 10 years ago and have not had any problems.
I just wanted to know if the part number on the AGCO website has everything I need. I doubt my local dealer will know.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SilverShoes Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2025 at 6:17pm
That’s what I did. Siliconed the bolts and around the edges.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Northern Hoser Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2025 at 8:11pm
Looks like 71504012 is the roll of foam gasket
               71507421 are the rubber washer gaskets, 16 required for the outside bolts
there are a couple of other smaller washers for the inner bolts but showing NLA
