Disc ID
MBolton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MBolton Quote  Post ReplyReply Direct Link To This Post Topic: Disc ID
    Posted: 03 Jan 2011 at 1:56pm
Here are photos of my disc . I'm hoping forum members can identify the model and tell me if it originally had an adjustment level/screw. TIA!
Post Options Post Options   Thanks (0) Thanks(0)   Quote MBolton Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2011 at 1:58pm
I meant to say "lever" not level!
KenB
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2011 at 2:53pm
I've got the front 'section' just like yours so I'd like to know too !
KenBWisc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2011 at 8:43am
Bump
'34 WC #629, '49 G, '49 B, '49 WD, '62 D-19, '38 All Crop 60 and still hunting!
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2011 at 1:59pm
From what little I know, I believe it's a #8 disc.  I had a #10 disc and donated it to Dale's museum in Paris, IL.  The #10 was a little wider and heavier.
The present position it is in is considered "transport" mode so you could pull it around the barnyard (or gravel road) without doing much damage.  To get the gangs to pivot forward and backward you need to pull up on the levers (toward the front of each tongue).  If you do this when hooked up to the tractor, then all you have to do is either drive ahead (or back up depending on whether you're moving the front or back gang) and the framework will move to allow for pitching the gangs forward/back for fieldwork.
Hope this helps.
Brian F(IL)
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2011 at 9:23am
Thanks Brian!
KenB
RichinWis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RichinWis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2011 at 10:41am
I believe that the disc models were 8, 9, and 10 respectively, The one I had was a No. 9
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jan 2011 at 11:06am
I have a 6 foot disc just like that, Dad got new with the 47C he first had.. Other than setting the angle of the gangs, the only other adjustment is how many cement blocks(or field rocks) you put in the tray. Charlie
BrettPhillips View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2011 at 9:37am
The disc in the picture is a 6 ft. #9.  Looks to be a pre 1950 model, since it has the spring loaded scrapers.  Later ones had one piece scrapers.
This page was generated in 0.056 seconds.
