HD 11 tracks
Sids View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sids Quote  Post ReplyReply Direct Link To This Post Topic: HD 11 tracks
    Posted: 16 Feb 2025 at 3:24pm
Looking for new or used tracks for early hd11. Do not have sn as ripper frame covers it. 516 engine, dry clutch 3f 3r. 38 links.
Have checked with some salvage yards, no luck. Send a message if anyone has any ideas.
Lazyts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lazyts Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2025 at 10:14am
HD9 links are the same, also HD7G, 37 links though on 7G and 7GB I think.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2025 at 1:43pm
NLA, and Unobtanium in the States, Can still get in Italy but Not Here.  7.0 pitch 177.8mm.  Cat at one time offered a set of Segments for later 11s, so could run 6.91 pitch or 175.5mm.  Also NLA.
AC Mel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC Mel Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2025 at 8:01pm
Sid...Tell us more about your tracks. Are you talking about worn grousers? Are the pins and bushings worn? Are the rails worn? Can you post some pictures?  We probably have some used tracks we might sell...we're in Ca....so freight would be expensive
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2025 at 10:44pm
You CAN still get them new via China matching the OEM in quality but you've got to be willing to pay for it. I have new, freshly made pins and bushings in wood crates for my 11B, and they are just as good as Berco or anything else you can find. I need to make the master set come to think about it as quantity of two each was below minimums...... They came from China and about three months wait time to arrive with all the customs clearance and such.
That's All Folks!
Sids View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sids Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2025 at 8:26am
I am in north central Kansas, -4 degrees and going lower tonight. But I will get some pictures soon. Pins, bushings and chains are all bad. Some links down almost to pin hole. Tractor spent most of it's life in very sandy ground. Thank you for your reply.
fjdrill View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote fjdrill Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2025 at 8:53am
There is an older straight shift about 20 miles SW of Tupelo MS.  I went to survey it for a guy for purchase. It had rained down exhaust (stuck motor). Had a nice under carriage if I'm remembering right. Old guy that has passed wanted $3500 for it. I'm sure it can be gotten for less now. A tree is growing up thru it last time I was by 2 weeks ago. PM me with your # and I'll stop buy and get their contact # If interested.
