mag verses distributer
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Topic: mag verses distributer
    Posted: 10 Feb 2025 at 1:32pm
why does it seem like a mag lasts much longer without any attention compared to a distributer  they both have the same basic componants
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2025 at 1:53pm
most MAGS are 75 years old , back when things were built with QUALITY... compared to the newer distributors that are designed by COST  ?????????
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2025 at 2:43pm
These magnetos reverse polarity through the points with each change of the magnetic polarity from North to South, etc. as it rotates. Any transfer of material gets reversed with each subsequent change. Distributors always transfer material in the same direction, and occurs not only at the points, but also at the rotor tip and cap terminals.
In a distributor with breaker points, when the balance between the capacitance (in the condenser) and the inductance (in the coil) are perfect, there will be no transfer of material in the points. If you ever see this happen, do NOT touch it!
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2025 at 3:13pm
Try to find any distributer parts today that are of the quality you could find 25 years ago. Magneto parts available ate this point are probably that old and when they're gone, they're gone.
dkattau View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dkattau Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2025 at 3:26pm
Mags were probably built for a more severe environment than distributors.
Edited by dkattau - 10 Feb 2025 at 3:30pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2025 at 4:12pm
60 years ago distributers still had to have regular maintance
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2025 at 11:44pm
I beg to differ. I would take a Distributor any day over a Mag.  I rebuild Mags, but I'm slowly moving away from rebuilding them due to the lack of good quality service parts. Quality parts for Mags have diminished. The cost to rebuild a Mag now a days gets pretty expensive depending on age, mfr. model, series & condition.  With a Distributor, you can at least still get decent quality parts for them (non Chinese) as well as adding an optional electronic ignition. Like anything else mechanical, Distributors need to be attended to and inspected once in a while as well. Keeping a good EP Moly grease in the drive cavity is a plus to keep gear mesh wear to a minimum, as well as checking Distributor main shaft runout for peak performance. In most cases, a properly rebuilt Distributor top to bottom will give many years of service with normal intermediate inspections. I've changed over many a frustrated customer from a Mag to one of my Mag to Distributor conversion kits, and they never looked back whether points or E.I.
Steve@B&B
