Wd stuck exhaust valves
ToddnwIl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ToddnwIl Quote  Post ReplyReply Direct Link To This Post Topic: Wd stuck exhaust valves
    Posted: 09 Feb 2025 at 5:00pm
I've recently inherited a wd that used to run. Prolly bin 10 years or so. Got it turning over well and the carb cleaned. Still couldn't get it to run. Today I did a compression test. No compression on the middle two cylinders. So I pulled the valve cover and the exhaust valves are stuck open. Any old school tricks to loosen them without pulling the head.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2025 at 5:33pm
Lots of penetrating oil from the top side. Get about 10 ft of nylon rope small enough in diameter to shove down inside the spark plug hole (5/16" ?) while the piston is at BDC. Have a knot tied in the rope so you don't lose it. Turn engine over by hand with all that rope coiled up inside. Rinse and repeat for the second cylinder.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ToddnwIl Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2025 at 6:04pm
Awsome idea!!! I'll give that ago. I knew their had to be an old school trick!!!
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2025 at 8:29pm
KROIL will help free them up. KREEN is even better than KROIL for stuck rings and valves.
KREEN is made by KANO Laboratories, Nashville, Tn.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2025 at 8:39pm
besides the penetrant, tapping on the end of the valve can help SHOCK it.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2025 at 9:33pm
take the rocker shaft off and start tapping on the valves with a plastic or rubber hammer besides you will need to make sure allof them move smooth.     and you will need to replace the push rods that got bent when you got it to roll over
Post Options Post Options   Thanks (1) Thanks(1)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2025 at 9:45pm
tap the stem not the retainer
Post Options Post Options   Thanks (0) Thanks(0)   Quote ToddnwIl Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2025 at 7:56pm
Alittle update. The rope trick worked perfectly! We soaked them down really well. 20250210_180357.jpg20250210_180909.jpg
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2025 at 7:57am
Nice! Smile
I used the rope trick last summer on my Model C to hold the valve up when I replaced a broken valve spring.
ekjdm14 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ekjdm14 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2025 at 8:50am
Sweet have heard of the rope trick for replacing valve springs retainers etc but never thought of it for pushing up on stuck valves. My normal go-to is either vice grips or a couple of pry bars on the retainer,
Post Options Post Options   Thanks (0) Thanks(0)   Quote ToddnwIl Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2025 at 6:43pm
Another update... got everything reassembled and did a compression test done. Number 3 cylinder still has no compression.   Any more tips or tricks before I pull the head. Gona barrow a buddy's bore scope tommorow and see if I can see anything.
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2025 at 8:06pm
Probably one of those valves on #3 is still not seating properly.  Tap on the valve and use more penetrating oil and it may loosen up and seat.  It may also have a burnt valve and then the head will have to come off.
jvin248 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2025 at 8:43pm
Could be a bit of gunk/rust stuck on the valve.
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2025 at 9:50pm
If the valves on that bad cylinder are moving up and down AND have proper valve ( I'd set them loose at .030" to start) lash, get it running on the three good cylinders and run it a while and see if it comes out of it. This will cost you nothing to try.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ekjdm14 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2025 at 5:27am
100% agree, set the valves loose (or leave adjustment where it is if already on the loose side) and run it a while see if she comes back around.
The reason for setting/leaving the valves loose is because if there's gunk under the valve the clearance will come back smaller as it wears away.  As the Doctor said, costs nothing to try. Compression went up noticeably on my B after getting it running for a few minutes (previously it had some compression on 2 cylinders & very very little (couldn't feel it on hand cranking) on the other two.
At the very least, it'll get your motivation up hearing her run & give you a chance to verify oil pressure even if you do end up tearing back into it.
Edited by ekjdm14 - 12 Feb 2025 at 5:29am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2025 at 6:32am
And if you run it for 30 minutes or more at a throttled up/wide open speed, you'll be able to determine if it smokes BLUE or not, indicating it needs an overhaul, including pistons and sleeves.
This page was generated in 0.093 seconds.
