shallow well pump teardown
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Topic: shallow well pump teardown
    Posted: 04 Feb 2025 at 8:41am
OK, got a shallow well pump FREE, rusty cast iron 'pump', 'Assembled in USA, 3 languages' motor.
Removed the 4 bolts and pried the two apart maybe 1/4" . Cut the little airline.
Is there some 'magic' to separate the two ??
Supposed to be a 'fun, winter project'.....
Any help is appreciated
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2025 at 8:48am
normally the BACK cover will pry off as you overcome the stuck bearing... the FRONT COVER has the bearing and water seal... you need to unscrew the impeller first to get that cover off............ i am in the process of same WINTER project.... front bearing of motor bad.
this is very similar to the one i am doing..your may be a MUCH OLDER design if it was actually built in the USA.
Edited by steve(ill) - 04 Feb 2025 at 9:00am
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2025 at 9:25am
well I FINALLY got the pump front end off ! two small pry bars,pry a bit, move bars, repeat,POP it came off.
So far 1/2 big coffee can of RUST and more to come. At least garage is warming up so now it should be fun.....
good luck with yours !!
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2025 at 9:44pm
Take the parts to the bead-blaster, you'll probably find most of it cleans up like new.  If the motor windings are still good, and no impeller hubs spun out, a set of seals and bearings should have you back in high cotton pronto!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2025 at 6:39am
thanks ! Just something to pass the time ..
got 90% of the rust out with chisels and small hammer
odd that Google  can't find any info about the pump
oh well....beats sitting in front of the 'idiot box' !
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2025 at 7:43am
I did a similar project on a shallow-well jet pump about three winters ago... it was a 2hp 2-stage, locked up with rust.  Two new seals cost under 30 bucks, bearings were about $40, and there was a plastic injector nozzle that'd embrittled and fractured... I found a replacement for $20.  It went through the bead blaster, got fresh paint inside and out, and works like a champ.  It was out-of-production, but it's equivalent replacement was over a grand, so that was a worthwhile winter project, hope yours turns out as well!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2025 at 8:04am
Similar pumps here in Canada are north of $500 now !!! It was used for rainwater cisten so pretty clean. Managed to 'derust' the rubber gasket on the plastic insert in the pump. Destroyed the paper gasket between pump and motor, might cheat and use silicon, but have to wait until Spring.
This page was generated in 0.199 seconds.
