D-17 oil pan
BLee Mn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BLee Mn Quote  Post ReplyReply Direct Link To This Post Topic: D-17 oil pan
    Posted: 01 Feb 2025 at 6:12pm
dropped the eng oil on my sisters D-17 stuck my finger in drain hole and there is a loose piece of steel laying in the bottom of pan,   is it supposed to be a baffle of some sort? that  has come loose?
Edited by BLee Mn - 01 Feb 2025 at 6:12pm
Cowboy UP
RedHeeler79 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote RedHeeler79 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2025 at 6:26pm
The oil pump pickup is there. It has a flat steel shield covering most of the mesh screen and it is on the very bottom. The pickup assembly is not solidly mounted and can move up and down slightly. Hopefully this is what you are feeling with your finger in the drain hole. Otherwise, yank the pan off and find out what came loose… depending on year of tractor and steering setup, can be a big job just pulling the pan.
Edited by RedHeeler79 - 01 Feb 2025 at 6:30pm
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2025 at 6:07am
Nothing should be loose on the bottom of the pan.  Get a bore scope and see whats in there.
AaronSEIA
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2025 at 7:45am
Legit D-17 engines had a floating oil pump pickup screen. It moves up and down 2 inches.
