D-19 Largest Mounted Attachment? |
wjohn
Topic: D-19 Largest Mounted Attachment?Posted: 06 Jan 2025 at 8:03pm |
I know this is a loaded question, but what's the biggest thing you've hung off the back of a D-19 (Snap Coupler or 3-point)?
Only reason I ask is that I have been offered a 3 point mounted 610 chisel (the one made by Jeoffroy for AC). The biggest thing I have is a D-19 and I don't anticipate ever needing anything larger. The chisel looks too big for it but I figured I would ask for the wisdom and experience of the forum. ![]() |
im4racin
Joined: 12 Jun 2017 Location: Garrison ND Points: 1125 |
Posted: 06 Jan 2025 at 9:23pm |
Oh… To be in a part of the world that doesn’t need spring trip on chisel plow shanks!
wjohn
Posted: 06 Jan 2025 at 9:59pm |
Actually, we probably do. I got my CII from this guy and plenty of rocks busted the bottom of the grain header pan over the years. Go 10 miles west of us and no more big chunks of limestone. I was at least able to lift all the rocks I found in my fields by myself this year, so that was nice.
Posted: 06 Jan 2025 at 10:16pm |
Is it category 3 ??? if so, it ain't for a D-19.
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3671 |
Posted: 06 Jan 2025 at 10:46pm |
wJohn, what tractor did the previous owner of this AC chisel pull it with?
KJCHRIS
Posted: 06 Jan 2025 at 11:26pm |
I see there's 8 shanks on it, but some have been removed & it's 3 pt. Do you have 3 pt on the D19.? Can it lift the chisel and drive with it, or does frontend come off grd? Do you have duals?
The gauge wheels will help keep it from dropping to china & lifting frontend into air. I'd try it with 6 shanks spaced evenly & gauge wheels set about 8" off ground setting on level hard surface then see if it will pull it that way. IF it has no problem handling it, set wheels higher or put the other 2 shanks on.
Allis dave
Joined: 10 May 2012 Location: Northern IN Points: 3132 |
Posted: 07 Jan 2025 at 5:53am |
I've pulled a 7 shank with my 185. No trouble on power, but I have just barely enough traction with loaded tires.
Lars(wi)
Joined: 14 Sep 2009 Location: Permian Basin Points: 8402 |
Posted: 07 Jan 2025 at 6:46am |
D-19 gas, or diesel?
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12420 |
Posted: 07 Jan 2025 at 7:29am |
So probably if you had plenty of traction, you’d be low on power!
Gary Burnett
Joined: 11 Sep 2009 Location: Virginia Points: 3200 |
Posted: 07 Jan 2025 at 7:50am |
We ran a D19 for years loved it but no way it would have pulled that chisel plow in our red clay,Take off half the shanks to start with.I had a 5 tooth chisel I pulled with the 190XT I owned and the 190 had all it wanted.
mruhlig77
Joined: 19 Aug 2014 Location: central Indiana Points: 597 |
Posted: 07 Jan 2025 at 10:34am |
Pull it with a well weighted tractor until something pops....going for 10 or 1000 acres???
Michagman
Posted: 07 Jan 2025 at 6:16pm |
I can't answer your question, but I have one of my own. I assume it's a 3-point. Has it been partially unbolted and folded down for some reason, or does the top link pin do double duty?
wjohn
Posted: 07 Jan 2025 at 7:24pm |
The biggest tractor the guy had when he was farming was a 4020 diesel. I am now wondering if it was too much for the 4020 and that is why some shanks are missing.
Thanks to everyone for humoring me. I may buy it to cut it down into something smaller if the price is right.
