rear PTO oil seal
rick ky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rick ky Quote  Post ReplyReply Direct Link To This Post Topic: rear PTO oil seal
    Posted: 21 Dec 2024 at 6:32am
single PTO speed shaft oil seal, allis chalmers #70241779, not Looking for measurements. Looking for federal mogul, skf, CR or national numbers for this seal. Unfortunately, if I can not help the people behind the counter they can't help me
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2024 at 7:18am
70241779 is discontinued ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2024 at 7:45am
It is available through agco but comes as a five pack. We should have some available or I can look in the fast moving book for cross number
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2024 at 8:05am
My  Agco Dealer has Six 70241779 in stock 12.09    NAT # IS 450135-- CR # is 13649
Post Options Post Options   Thanks (0) Thanks(0)   Quote rick ky Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2024 at 1:36pm
thanks to Alvin, many people are upset not using 100% agco, but if the quality is there seals, bearings and anything else is alright by me. I once bought a water pump from a agco dealer and under the agco label on the box was a hy-capacity label.  I appreciate the cross reference to finish todays  project. the salesman at KOI, has wd45 and d17 and knew exactly what we were asking to use it on. thanks again Alvin
Post Options Post Options   Thanks (0) Thanks(0)   Quote rick ky Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2024 at 1:38pm
PS we stopped the leaking today. thanks again Alvin
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2024 at 3:19pm
Your Welcome  rick ky I Like To Help Where I Can  Worked On Allis 60 Plus years
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2024 at 8:39pm
I recently replaced bypass filter on 8070 oil change. AGCO # on box...Wix filter inside.        Not a negative but a surprise.
This page was generated in 0.191 seconds.
