WC front wheel question
khoney View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote khoney Quote  Post ReplyReply Direct Link To This Post Topic: WC front wheel question
    Posted: 03 Dec 2024 at 7:20pm
Is this front wheel on a WC something from Allis or just some will fit wheel that was installed sometime in the last 70 years
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2024 at 9:40pm
wonder if it orignaly had spoke wheels
Post Options Post Options   Thanks (0) Thanks(0)   Quote khoney Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2024 at 10:04pm
Do not know, just purchased it.  Never seen this type of wheel.
kevin LA-CA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kevin LA-CA Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2024 at 7:47am
I believe it is aftermarket. Targeted for McCormick-Deering / international. The 3 bolt hub cap is used on F20 and 10-20 tractors. Hs and Ms too. Probably for steel to rubber conversion.
I thought it was made by F H, but don't have confirmation
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2024 at 7:49am
Pretty cool regardless
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2024 at 11:07am
Very nice. The color looks right for AC. It reminds me of Oliver.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2024 at 11:24pm
That is a French & Hecht 'convertible' wheel.  It could be used with a narrow steel bladed rim, a larger round flat rim, a Dayton type wheel rim with wedge clamps, or a rim with a tab-type clamp.  They could also be used on towed implements with a bolted-on ring gear, but I've never seen that derangement.
These are most frequently found on steel-wheel green tractors, and red tractors all of vintage prior to 1939 or so.  I believe these wheels came out of the F&H foundry in Davenport, Iowa, and were probably shipped just across the railroad deck of the Government Bridge to the IH and JD facilities in Moline.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2024 at 11:27pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote khoney Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2024 at 9:13am
Thank you DK for the good info.  I will leave them on the tractor as they do look neat.
This page was generated in 0.107 seconds.
