tach drives |
d17brown
Joined: 11 Sep 2009 Location: farley iowa Points: 1729 |
Topic: tach drivesPosted: 20 Nov 2024 at 6:31pm |
It appears there are two different ratio drives for the alternator drives for the tach. Does anyone have the slower ratio drive set up
phil
KJCHRIS
Posted: 20 Nov 2024 at 9:03pm |
12 & 45 tooth are the only one I remember on an Allis that's alternator driven.
I think MF used similar on a few models but no experience with them.
Joined: 11 Sep 2009 Location: illinois Points: 88631 |
Posted: 20 Nov 2024 at 10:07pm |
pulley size also effects alternator speed
KJCHRIS
Posted: 20 Nov 2024 at 11:50pm |
Yes, pulleys differ and can really change speed of alternator.
Sorry, My notes don't have the offset dimensions. PULLEY SIZES
170, 175, 180, 185 use; a 1/2" belt x 3 15/16" OD x .670" bore. 190, 190XT and F & G combine; a 1/2" x 3" OD x .670 bore. 200; 2 of 1/2" belt x 3 1/8" OD x .670" bore. D19, 210, 220; 2 of 1/2" belt x 3 1/4" OD x .670" bore. 7000; 2 of 1/2" belt x 3 1/2" OD x .670" bore. wider offset. 6060, 6070, 6080, 7010, 7020, 8010; 2 of 1/2" belt x 3 1/2" OD x .670" bore. narrow offset. Bigger model 7000's and 8000's use 2 pulleys; 1 narrow offset w keyway & 1 wider no keyway both 3 1/2" OD & use 2 of 5/8" belts. |
Alvin M
Posted: 21 Nov 2024 at 5:51am |
M F is 14x23 that will change the tack speed I had some like over the years AC is 12x45
