d21 fuel pump |
allisqc
Bronze Level Joined: 11 Apr 2018 Location: Canada Points: 5 |
Posted: 17 hours 40 minutes ago at 1:57pm |
I need to remove fuel pump on my d21. To turn engine for timing he have other way than remove starter and turning flywheel with prybar? I Have no space to turn by the crankshaft nut.
injpumpEd
Orange Level Access Joined: 13 Sep 2009 Location: Walnut IL Points: 4913 |
I can usually turn them over backwards with the fan, just push on the belts while pulling the fan carefully.
allisqc
thank you, I will try
DougG
Orange Level Joined: 20 Sep 2009 Location: Mo Points: 8108 |
Should be a hole under the clutch housing to get a stout screwdriver in there to get on the flywheel teeth, thats the best way ,
Edited by DougG - 15 hours 14 minutes ago at 4:23pm |
55allis
Orange Level Joined: 30 Jun 2020 Location: Griswold Iowa Points: 703 |
Make sure you tie throttle in wide open position if you pull the pump off…
It will drop the governor weights if that shaft comes out… learn that the hard way and destroyed a pump, and now I will tie that just for peace of mind… |
