Steering Gearbox experts?
Grant Forsythe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grant Forsythe Quote  Post ReplyReply Direct Link To This Post Topic: Steering Gearbox experts?
    Posted: 07 Nov 2024 at 6:44pm
Anyone on here or know someone who can help me figure out a replacement gearbox for an old reverse loader? It's a Gemmer. I found one the same size but it steers backwards.
The Unstyled Collector
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2024 at 7:33pm
Would it be possible to remove the ARM from the shaft and move it 180 degrees ?  If it points DOWN, you can point it UP and it will PUSH instead of PULL ( reverse)...im not familair with your loader, if there is room for that or not.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grant Forsythe Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2024 at 8:20pm
The thought crossed my mind but the drag link is so long it wouldn't clear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2024 at 8:26pm
I assume your loader is based on the older WD or D series tractors... Not sure about their gear boxes... But on the Smaller B- C tractors, the two boxes were OPPOSITE of each other..
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2024 at 9:25pm
Posting the Tractor Model or a complete picture would certainly help.
G
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grant Forsythe Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2024 at 6:47pm
It's a TLW, they made 202 of them. No one will have parts for it. Will have to cross reference everything to another application. forklift, right hand drive vehicle, maybe another reverse loader.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2024 at 7:52pm
link to some photo - discussion...
i assume your gears are so torn up you dont think it can be rebuilt ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2024 at 8:17pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grant Forsythe Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2024 at 6:54pm
The TLW from that other post is coming to my place this winter for a steering gear box replacement from the power steering that was added. I am building 2 gear boxes from some ford (gemmer) gear boxes. The ford steers backwards of the TLW. I plan to call that place tomorrow but have been warned they only sell parts after they inspect my box for a fee.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2024 at 7:05pm
Grant... that sounds interesting... post some photos of your work if you have time !!
This page was generated in 0.115 seconds.
