18hp Kohler engine
DaveWisc. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveWisc. Quote  Post ReplyReply Direct Link To This Post Topic: 18hp Kohler engine
    Posted: 04 Nov 2024 at 6:55pm
Is the exhaust gasket the same as the 16 hp or need number for it
acken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acken Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2024 at 7:39pm
Single cylinder 16 hp Kohler had elbow threaded into block, no gasket.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveWisc. Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2024 at 7:56pm
Well not the same then thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveWisc. Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2024 at 8:08pm
Where can I get a exhaust gasket for a 361 Kohler engine
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2024 at 8:52pm
That it
Edited by Mikez - 04 Nov 2024 at 9:10pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveWisc. Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2024 at 9:10pm
You have one Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveWisc. Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2024 at 9:11pm
Looks like it for single cylinder Kohler 361
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2024 at 9:12pm
I just edited it. Had wrong picture. Look again. That’s for 18hp Kohler correct
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveWisc. Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2024 at 9:17pm
Yes Kohler 361 single cylinder
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2024 at 10:32pm
Oh I was looking in Kohler twine 18 hp. I’ll keep looking. Or does it look like this
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2024 at 10:41pm
Found a gasket kit for one…
Can see the exhaust gasket in background of the picture.
https://isavetractors.com/gasket-set-for-kohler-k361-18hp-ohv-engine/
1955 AC WD45 diesel with D262 repower, 1949 AC WD, 1963 A-C D17 series 3
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2024 at 5:52am
Post a photo of the tag, or decal on the engine and I'll grab one from the shelf at the dealership. They are a Kohler Engines dealer.
That's All Folks!
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2024 at 6:01am
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2024 at 9:24am
Like most K Series engines, the exhaust port is threaded but there are two threaded holes as well for a gasketed connection.
I "assume" the !8 HP might have the 1-1/4" pipe thread like the 16 HP rather than the 1" size on the smaller K-series engines.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2024 at 10:09am
is it a 16 magnum or a ch16?  model and spec number would help
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2024 at 10:35am
this is my K361 out of my PowerKing 2418
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2024 at 9:59am
Well, that proves my "assumption" was wrong......no pipe threads!
I always thought sticking a pipe fitting in the exhaust port on these engines just increased the back pressure anyway.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveWisc. Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2024 at 4:57pm
Mine has no place or threads for a pipe just the two studs
