Just curious |
rdean33422 ![]() Bronze Level ![]() Joined: 03 Sep 2022 Location: Florida Points: 7 |
![]() ![]() ![]() ![]() ![]() Posted: 12 Oct 2024 at 6:41pm |
What year did they start putting distributors on WD tractors? Thank you Ray
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21759 |
I know my Dad's bent gearshift late 1952 or 1953 WD had factory distributor ignition. Not the add-on style that bolted up to the mag drive.
WF owner ![]() Orange Level ![]() Joined: 12 May 2013 Location: Bombay NY Points: 4989 |
My 50 WD has a mag.
Bill Deppe/AC Salvag ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Maquoketa, Iowa Points: 973 |
WD parts book indicates distributor began with sn 136318
So that would be quite early in 1954.
allisorange ![]() Silver Level ![]() ![]() Joined: 27 Mar 2010 Location: perkins, michig Points: 381 |
We bought a 1952 new and it had a distributor. J. Carlson
WD-45 production started at chassis s/n 146607 in summer/fall of 1953. WD's started distributors at 136318 which is also 1953 and about 10,000 tractors before the WD-45 started. Looks like no battery ignitions in 1952 according to the parts book. Sometimes mistakes are made, but that's what it says.
Gary ![]() Orange Level Access ![]() Joined: 13 Sep 2009 Location: Peterborough,On Points: 5899 |
I checked the CA Parts Catalog: Generator, Electric Starter, and Distributor all started at Engine Ser. 149840. Couldn't find any Tractor Serial Number to correspond to this Engine Serial. Checked Bryan Smyths 'Tractor Ser. - Engine Serial reference Year Tractor SN Range Engine SN Range 1950 14 - 321 140553 - 141017 1951 322 - 10538 141018 - 156449 1952 10539 - 22180 156450 - 174033 1953 22181 - 31423 174034 - 187993 That indicates about mid 1951 for CA Distributor. Gary |
Dr. Reading this Forums 'Serial Number Reference' Chart: I get the same conclusion as WF. 1954 WD 1st 131243 last 160384, since early Serial Numbers posted are ending #s Ser. 136318 falls in this range, so a 1954. BUT the 'Serial Num. Ref.' states "** WD-45 production began at 146607 in 1953" Something is not right. perhaps WD-45 started in 1954 ? I have a picture of myself sitting on a brand new WD-45, with another one parked in view behind it. This would have been when my father first started with his Allis Chalmers Dealership. Unfortunately there is no date on the picture. G |
Straanger ![]() Bronze Level ![]() ![]() Joined: 10 Dec 2019 Location: Michigan Points: 57 |
We like pictures
Me too Straa, but I never learned how to post pictures. Guess I should learn. G |
jvin248 ![]() Silver Level ![]() ![]() Joined: 17 Jan 2022 Location: Detroit Points: 445 |
. Just random data add: 1952 WD WF 125xxx with distributor on mag mount (suspect dealer/aftermarket) 1952 WD NF built two weeks before with magneto First is the one I have now, bought a few years back. The other was my father's that we had when I was a kid that my brother has currently. We tried getting our father's running but got the mag gears indexed wrong and need to get back to it. . .
Edited by jvin248 - 13 Oct 2024 at 7:17pm |
AC720Man ![]() Orange Level ![]() ![]() Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5209 |
My 52 has a distributor. Would have to check to see what the S/n is
Thank you all for the replies My serial number is some what messed up on my tractor so the best I can tell it is either a 1949 or a 1951. WD with a magneto and a straight gear shift lever. Thank you again Ray
IBWD MIke ![]() Orange Level ![]() ![]() Joined: 08 Apr 2012 Location: Newton Ia. Points: 4049 |
This is all correct. Where the 1954 thing comes from I don't know. To expand a bit, the snap-coupler hitch became standard equipment at serial number 151381. I believe it was optional before that and many WD tractors have been retrofitted, I have one of those. Diesel engine production started at serial number 181341, 4 bolt wide front ends corresponding with this. I'm not 100% certain on this but pretty sure. Couple other random thought on this as I'm paging through the bible; My Grandpa's WD that he bought new is 115xxx and came with a mag. and straight stick. It's still here but now has battery ignition I installed. On page 80 of Norm's bible there is a picture of a 45 with 15-28, (18.4x28) rice and cane tires that were a factory option. I mention this because there was some controversy at Hutch about my 16.9x28's being larger than "stock" tire size. There was also a diesel in the 5000 lb. farm stock with the same size tires. I don't remember him getting any flack about his tires but I digress. Maybe next year I should take the book with me and show them that picture?
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24594 |
re: What year did they start putting distributors on WD tractors? 3 days after some engineer got out of the hospital with his busted up finger,wrist and shoulder ?
