Power Steering Control Valve.
MrH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrH Quote  Post ReplyReply Direct Link To This Post Topic: Power Steering Control Valve.
    Posted: 01 Oct 2024 at 12:12pm
I have a D17 series iv and I just got the motor replaced. Everything is fine except the fluid is leaking out from the Power Steering Control Valve assembly. Actually, from around the worm shaft and the seal from the rear cover. I'm thinking that the seal needs replaces and wonder if anybody can tell me where I can get the seal.
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2024 at 1:32pm
AGCO Part # 70229725 they have it in stock
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2024 at 2:14pm
AGCO has the seal.  You have to roll the axle out from under the tractor.  Easy fix.  Done many of them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2024 at 4:03pm
I just take the steering shaft off remove the coupler remove the cover then you can change the seal don't need to remove front end that way
This page was generated in 0.273 seconds.
