Early 1950’s linoleum………
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Topic: Early 1950’s linoleum………
    Posted: 19 Sep 2024 at 6:14pm
Being removed from hallway, and probably kitchen.
Was underneath 1980’s wood grain laminate made of some type of rubberized plastic petroleum product.
The linoleum isn’t coming up easy. The black adhesive mostly remains on the hardwood floor. What’s the best course of action to remove this 70 year old adhesive?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2024 at 6:15pm
Be cautious with those, the Tiles in the 30s 40s and 50s had Asbestos in them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2024 at 6:19pm
If they are 9 x 9 size, there is 100% chance of them being asbestos... If other size, and built before 1960, still some chance... As long as your scraping and its comeing up in CHUNKS, thats OK... DO NOT GRIND.. NO DUST...
BEST way to do it is to screw down 1/2 inch plywood OVER the stuff and START OVER.
thendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2024 at 6:37pm
Don't know about linoleum, especially of that vintage, but a heat gun works wonders on peel and stick tile. Might be worth a try
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2024 at 6:40pm
This is actually rolled linoleum. Not brittle like the tiles. We want to try and go back to the hardwood floor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2024 at 7:20pm
i think the HEAT is a good idea... Most "GLUE" turn gummy when heated and can be scraped with a wood chisle or putty knife.
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2024 at 8:50pm
Lookup "Asbestos Abatement Procedure"
 If the tile is that old it's very likely it contains asbestos.
 My house built in 1955 has 1 room with the original tile on floor, the others are hardwood floors. At purchase I got a Notarized letter stating this 1 room has asbestos in floor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2024 at 8:54pm
In many cases if the tile were not asbestos , the glue contained it .
The remediation is to dampen it when scraping ,
There is a orange based glue removal product I got from a Janitor Supply company to remove glue from concrete where carpet had been glued down (glue was known as Green Death) as it seemed to even defeat a power razor knife machine .
 Product was expensive but result was clean floor once glue was scraped off , it turned into stringy paste and easily removed - then water washed floor .
 I had tried several solvents until I talked to my supplier on products to try , the stuff worked
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2024 at 6:34am
One all the linoleum is removed ,so just the black adhesive remians,get a pro floor sanding guy in and ask him CAN the floor be saved ?
I was lucky, after we removed the carpet, he said you've got ONE ,LIGHT sanding left.
whew....he did a great job..38 years ago.....most still looks real nice,cept for very high traffic areas.
If you go DIY, get the big square machine from Home Depot Rentals NOT a drum sander !!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2024 at 11:51am
Talked with one guy at our local hardware store, and described what I had, he said I most likely have ‘sheet vinyl’.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2024 at 11:48pm
You can get a power scraper or razor scraper from Rental places , take about a 8" cut blade and do a good job .
 The sheet goods are either vinyl or asphalt base material - but asbestos was used in the adhesive for many years
GSTROM99 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GSTROM99 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2024 at 7:27am
A couple years ago, I pulled the linoleum floor up in the kitchen.  100 year old farm house, but the kitchen was added in the 50's I think.  It had FIVE layers, all on top of the other!  No glue, but about 5000 little brads and staples to hand pull.  First course had felt paper below it, thankfully.  I have the original wood floor now, but still have not refinished it.
This page was generated in 0.250 seconds.
