Carb on an IB |
Freewheeling
Bronze Level Joined: 05 Nov 2017 Location: Wisconsin Points: 119 |
Posted: 4 hours 55 minutes ago at 1:05pm |
My 1952 IB has a Zenith carb # 10698A 212845. When the choke is in the closed position the lever is horizontal and the choke rod can't open it since it's in a downward angle. It appears the lever should be at something like a 45 degree angle. The lever is pinned to the choke shaft. I have a new choke shaft but it's splined and I don't have a splined lever. I'm thinking maybe either reposition the lever and drill a new hole in the existing shaft or replace the shaft with the splined one and drill a hole to pin it to the lever. Suggestions?
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 80090 |
im not sure of your description of the attachement.. EVERY B carburetor i have seen has a small block with a setscrew on it ON THE CARB LEVER... You slide the choke shaft thru the 3/16 inch hole in the block, then tighten the setscrew to hold it in place. That allows you to change the length of the choke rod.
If your ROD connects to the carb ARM and must be an EXACT LENGTH... You could cut and weld the ROD to a given length.... but this is not original. Edited by steve(ill) - 4 hours 21 minutes ago at 1:39pm |
this small block with the 3/16 hole in it slides into the carb ARM... the CLIP next to it holds it into the hole.. The block can swivel in the hole as the arm moves forward and back.. the BLOCK has a setscrew in the side to pinch the choke rod into postion.
not your model, but this shows the BLOCK and set screw - DESIGN.
Freewheeling
Yup, mine has the swivel block and set screw connection for the rod although it is defintely different. The lever on mine is on the inside between the carb body and the engine block. The rod goes through a hole in the gas tank mount and when it's in position and the choke is closed, the rod drops below the center of the choke shaft which makes it impossible for the rod to push the lever forward. I'm thinking that this is not the original carb. Is that piece to the left on the photo for the rod to go into as guide?
no .. that is a generic drawing... your choke ROD is a 3/16 ( guess) steel rod. It does not need a "clamp" at the carb... and yes, the choke is between the carb and eng block.
I guess what your saying is your ARM on the side of the carb is not INDEXED right to the CHOKE SHAFT... so the problem has nothing to do with the ROD..... when you close the CHOKE, your ARM is horizontal and not somewhat pointed UPWARD...... You are right, the ARM should go 45 degrees FORWARD (choke off) and 45 degrees BACKWAR ( choke on)..from vertical.... I think you need to reindex the arm... i have removed throttle arms and rotated a few degrees and solder back to the end of the shaft ( usually they are press fit onto a square end and then stamped or hammer on the end of the shaft to distort it and hold the arm on..
Edited by steve(ill) - 1 hour 55 minutes ago at 4:05pm |
double check inside and make sure the round choke plate is properly attached to the shaft... I have never seen a carb where the arm was horizontal when the choke was ON or OFF. ... the photo below is a good representation of what the ANGLE of the arm should be
Edited by steve(ill) - 18 minutes ago at 5:42pm |
