Allis WD PTO. |
Tom75
Bronze Level Joined: 07 Dec 2023 Location: Palmyra, Nebras Points: 15 |
Posted: Yesterday at 4:42am |
Ok, I’m laid up in the hospital after a surgery and my mind has been running wild so bear with me here. I have a baumalight 3 point tree saw that actually runs great on my Allis wd. My surgery was on my neck, and turning around to watch the saw is a real pain in the neck. lol. My question is, did Allis ever have an extended pto shaft that came out the front of the pto housing? If so, that would make it easy for me to built a 3 point mount for the front of the tractor and run the saw up front.
Edited by Tom75 - Yesterday at 4:46am |
AaronSEIA
Orange Level Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2542 |
Not that I know of, but it wouldn't be hard with a couple of sprockets and a chain to have a shaft go forward. AaronSEIA
Orange Level Access Joined: 12 Sep 2009 Points: 20165 |
I think the PTO box could be bolted on backwards with the output shaft pointing to the front.
Tom75
Thank you both! Both of those crossed my mind and I think they would work fine. I’ll have to check it out. I would really like to just turn the box and shaft around if that works. I will be a few weeks before I can actually do it but I’ll reply and let you all know what I figured out.
Also I’m not sure why Allis wouldn’t have done that. From the looks of that box, it looks like the shaft would slide all the way through. If I can’t flip the box, maybe I can flip just the shaft. |
Gary Burnett
Orange Level Access Joined: 11 Sep 2009 Location: Virginia Points: 2928 |
Cheap back up camera should solve the problem
Tom75
lol I have one of those too that go to my phone, and it’s mounted on an m18 battery.
Les Kerf
Orange Level Joined: 08 May 2020 Location: Idaho Points: 747 |
Many years ago my neighbor modified a WD PTO to attach a shaft going forward to run a home-built snow blower. There was just enough shaft protruding from the front for him to be able to machine the shaft to allow attaching a coupler.
WF owner
Orange Level Joined: 12 May 2013 Location: Bombay NY Points: 4593 |
I'm not familiar with the type of saw you are talking about, but why couldn't you put a pulley on the existing PTO and run a shaft the full length of the tractor (it probably wouldn't have much ground clearance).
I remember my grandfather running a circular saw for cutting up firewood and "sharpening" fence posts. They always wanted a belt so there was a slip-point.
Dennis J OPKs
Silver Level Joined: 12 Sep 2009 Location: Overland Park, Points: 415 |
The old side mount sickle mowers, WC era were driven by a fairly large V belt pulley mounted on the rear side of the pto box which in turn powered the mower shaft going forward and connected to the pitman arm. I doubt if there was a simple way to get power out of the front of the pto box.
Dakota Dave
Orange Level Joined: 12 Sep 2009 Location: ND Points: 3931 |
coming straight out the front of the PTO drop box the PTO turns the wrong direction. When putting an Erskine front blower on We had to add a direction reverser to make it work.
