2009 Ford Explorer |
Lars(wi)
Joined: 14 Sep 2009 Location: Permian Basin Points: 8402 |
Topic: 2009 Ford ExplorerPosted: 13 Sep 2024 at 8:56pm |
‘Tire Sensor Fault’ comes and goes. Sometimes will stay on for an hour, sometimes 10 minutes, sometimes all day. Would this be one of the sensors in a tire? Have this vehicle over 10 years, just started do this a couple days ago. All tires are at the proper psi.
Joined: 11 Sep 2009 Location: illinois Points: 90846 |
Posted: 13 Sep 2024 at 9:00pm |
YES.. each tire has a sensor.... each sends a signal to the computer.. If the pressure falls below 20 psi( example) then you get the "LIGHT".... Each sensor has a small battery to keep it going. Your batteries are 15 years old... Possibly that is the problem.
Bverwolf
Posted: 14 Sep 2024 at 1:23am |
We have an 07 explorer that did this. We replaced sensors and it still did it. A month or two later dome light would occasionally come on when driving due to the ignition switch getting bad. I replaced ignition switch and lo and behold tire pressure sensor fault never came back on! Asked a mechanic at the dealership about it and he saw the same thing once.
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35692 |
Posted: 14 Sep 2024 at 4:43am |
So many electronic boxes in the after 2005 cars, gets worse as move up in years as with our 2017 Exploder
Ford tech here noted are Seven in ours were four in you all’s and as of today 12 in newest. All dependent on power from a connectivity unit. You are lucky as to have a key switch, ours is Fob to Push button, a central ECM handles ours. |
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5278 |
Posted: 14 Sep 2024 at 7:00am |
Aren't all these computer controlled gadgets in newer cars wonderful when they start acting up?
Any vehicle ne enough to have a computer controlling everything is not anything I want. The vehicles I have will out last me, so I'll never be wanting a NEW vehicle. One big reason that everything now is controlled by a computer is the end goal of having idiot proof vehicles. case in point: Tire inflation sensors, I check my tire at least weekly with a gauge.
Posted: 14 Sep 2024 at 7:04am |
Another reason I reworked my '99 SD F250 and the '05KW, has only ONE ECM, has a small Rear ABS Module under the hood on the SD, the KW has one ECM and a ABS Module in the dash.
PaulB
Posted: 14 Sep 2024 at 8:26am |
ABS=All Brakes Suck. the 2 things I own that had ABS when new have has the ABS control unit removed. I first became familiar with ABS systems in the 70s with the 121 standard. They were OK for the first year or so, but after that you never knew if you would have brakes when you pushed the peddle or not. That system probably caused more accidents than it prevented. When look looking at semi trailers I discard anything new enough that the brake controls can not be replaced with old style non ABS controls.
