D 15 seat shock
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Topic: D 15 seat shock
    Posted: 03 Sep 2024 at 1:40pm
Have mine almost all the way forward in the fat boy position . No chance it'll ever bottom out . Seat does have a little bounce to it as is . Just wondering if it'd ride better adjusted the other way with a possible bottom out ? Or does it not make any difference ? My shock/spring is fairly newish and seems fine . Any input ? Should say I am kind of a fat boy.Thanks !!
Edited by ACinSC - 03 Sep 2024 at 2:21pm
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2024 at 3:11pm
Id move towards the rear a little at a time till it rode like i wanted it to
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2024 at 3:55pm
Thanks Donald. Guess a soft ride without bottoming out is the ticket.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2024 at 4:25pm
You are welcome sir
1984 80780
1957 D14
616 tractor
CA13414 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CA13414 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2024 at 6:16am
I put a new shock and spring our our CA since the old bottomed out in the front position.
With the new unit, I was able to move the seat to the back, and at 228 lbs, still had a bounce and only slightly bottomed out when I hit it hard.
Much more comfortable and I was not crowded into the steering wheel and petals.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2024 at 8:21am
Thanks D . I started at the back and moved it up until it just quit bottoming out. I've also drilled 2 new holes in the base so the seat sits back a little more.
