casting clock date codes |
mruhlig77
Orange Level Joined: 19 Aug 2014 Location: central Indiana Points: 578 |
Posted: 16 Aug 2024 at 10:01am |
How to read...clockwise or counter clockwise....is the top dot one or zero...thanks for the help...looking at a D-14
mruhlig77
surely you have seen the clock stamping under the right fender on the axle and other places on your D. series....Mark
ecosse23
Bronze Level Joined: 12 Mar 2024 Location: Scotland Points: 10 |
I believe the "clock" is read clockwise, and it reads from 1 to 12, with the "hand" or arrow pointing to the month of production. Similar notation is still used in plastic mouldings for things like TV's, computers and so forth.
mruhlig77
Thank you so much...I thought it was months...Is the letter codes like "J" year...
mruhlig77
I think there is more to learn here...
Orange Level Access Joined: 12 Sep 2009 Location: Greensville,Ont Points: 22472 |
Also the marking indicates the production date or a reference code, where the numbers represent specific details like the month and year of production
Allis dave
Orange Level Joined: 10 May 2012 Location: Northern IN Points: 2917 |
Google How to read Casting Codes
Orange Level Access Joined: 12 Sep 2009 Points: 20526 |
Thanks(1)
Let's use a 1937 "WC" transmission case actual date code on the right side. The code may read 12-10-36, which is the date the transmission case pour. But, your serial number of the chassis may indicate the tractor was a Spring build of 1937. Some will try and argue the tractor was built in 1936 because of that date on the transmission case. The reality is castings for engine blocks, transmission or rear end cases had to have a "cure" time of so many days or weeks before it could be machined and made a finished product. To not give the cure time would give you a casting that may change size and shape when put into service.
ecosse23
Thanks, I learned a lot from reading through the replies. There's another thread here that may be of interest to the OP -
