Allis 6080 Engine Oil level running or cold |
ssefick ![]() Bronze Level ![]() ![]() Joined: 09 Feb 2022 Location: South Carolina Points: 137 |
![]() ![]() ![]() ![]() ![]() Posted: 04 Jul 2024 at 11:23am |
Hello, I have a 6080 y'all helped me finish the rebuild on. I have a silly question.
Do you check engine oil on running side or stopped side? Stopped says full. Running says middle range. Just making sure I'm not missing anything. |
bigal121892 ![]() Orange Level ![]() Joined: 05 Jan 2010 Location: Nebraska Points: 772 |
Is the tractor running or stopped? I always check oil at the start of the day, with engine off, and the oil is cold.
Reads full cold. Low running. That is why I'm asking this question. I was a little confused.
Thanks! |
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 19789 |
The dipsticks on those engines were made so you COULD check the oil when at operating temperature on the level while IDLING. More of a gen set or irrigation pump application. You have no reason to do it that way !!! Check it cold, sitting still and not running.
Dr. Allis, thank you,sir! I appreciate it!
