D-10 series 3 pilot bearing? pilot bushing ? |
tractorboy ![]() Silver Level ![]() Joined: 03 Oct 2009 Location: southern Va Points: 453 |
![]() ![]() ![]() ![]() ![]() Posted: 29 Jun 2024 at 11:35am |
Bout ready to put son's engine back in. According to everything I read , supposed to have a pilot bearing. This one has a bushing that slides onto the larger shaft. I've ordered a bearing, & a bushing and neither will work. The bearing is too big to fit into the flywheel & the bushing is too small, only fits on the live PTO shaft. any help appreciated! keith so. va.
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8089 |
Some one said that series had live hyd and shaft was splined to flywheel
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 78815 |
skip down about 10 posts to Garys comment...
Yes that small shaft is splined into the flywheel, there's still a bushing that fits into the flywheel & slides onto the larger shaft. That size bushing doesn't match up with anything in DJ"s or Steiner's or anything I can find on fleabay. Guess I'll clean up the old one & reuse. keith so.va.
i think that was the conclusion... that the bushing that IS AVAIALBE is for the Series 1... not yours..... seems odd that nobody sells the NEW one.
Gary ![]() Orange Level Access ![]() Joined: 13 Sep 2009 Location: Peterborough,On Points: 5230 |
Part 'Description' The Ser.I part is titled BUSHING Clutch Shaft The Ser.II and III is titled BEARING ASSY. clutch The Ser.II and III Clutch Disc Assy. is different P/N than Ser.I G ................................................................... Dug up some old pictures I took when I replaced the Ring Gear in my D-12 Ser.III It appears there is a 'Bushing' in a rearward facing nose of the Flywheel. It would seem this Bushing / Bearing would support the end of the hollow Tube that is splined in to the Clutch Disc and powers the Transmission. Edited by Gary - 30 Jun 2024 at 8:14am |
Mikez ![]() Orange Level Access ![]() ![]() Joined: 16 Jan 2013 Location: Usa Points: 8216 |
236056 bushing is still available
8 digit number would be 70236056 - bushing.
