Husco valve assembly
Allis_Cooper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis_Cooper Quote  Post ReplyReply Direct Link To This Post Topic: Husco valve assembly
    Posted: 23 Jun 2024 at 7:52am
Hello, I am seeking a seal kit for the remote valve assembly on my 1975 AC 185.
The tag on it (as best I can read it) says: Husco   E000375
I've tried an AgCo dealer but they haven't gotten back to me. Does anyone on here know where to get such a kit for this assembly?
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2024 at 8:39am
I really would suggest you remove the valve and let a qualified hydraulic shop do the work. Husco is a good valve but like any, they wear in the bores and spools and a good shop can hone bores and rebuild spools if need be.
Of course any good hydraulic shop can supply you seals also only.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2024 at 5:22pm
70255229 is a seal kit for ONE valve section. 70261795 is a seal kit for ALL sections I think. Spools are made for a specific valve block and cannot have anything done to them like polishing or lapping.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2024 at 7:29pm
It is usually much less $$$ to machine new spools from purpose supplied raw stock than build up and regrind to dimension; though it can be, and is done. Bores are usually bored and reamed/lapped oversize, or sleeved than lapped to proper dimensions if bad. Did a lot of this work as an apprentice in years gone by.
Same principal with transmission shift rails and bores they slide in.
That's All Folks!
