8000 Serial numbers
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Topic: 8000 Serial numbers
    Posted: 17 Jun 2024 at 3:30pm
It appears that my 8030 does not have a serial number as seen on the product identification sticker.  Any explanation for this?
With that said, is the number on the rear housing the same as the serial number usually?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2024 at 3:47pm
Serial number stamped into the rear end housing just above the PTO shield and to the left.
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2024 at 4:05pm
If I remember my letters correctly its a fwa power shift # 2929
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2024 at 4:18pm
You are correct sir.  I found it unusual not to see it on the PIN sticker.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2024 at 4:39pm
almost looks like that housing is stamped over somother numbers
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2024 at 4:58pm
Myron
From the 2019 owner registry, Fred Dunlop has 8030 2621 84
Gary
SteveMaskey(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveMaskey(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2024 at 5:17pm
Here is mine
