One Sixty shifter boot
rms61moparman(Ky) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rms61moparman(Ky) Quote  Post ReplyReply Direct Link To This Post Topic: One Sixty shifter boot
    Posted: 16 Mar 2024 at 11:22pm
Can anyone point me in the right direction for the shifter boot for a One Sixty Allis? I can't seem to find one anywhere.
Mike
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2024 at 6:28am
Have you checked with AGCO? This reminds me, need to order one for the 6080.
ryan(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2024 at 7:51am
I’ll have to double check. Agco had them last year. Not cheap but better than getting water in the transmission
ryan
1984 8070 FWA,1979 7060,1975 7040,1971 190,1960 D-17D,1957 D-14, 196? D-19G, 1975 5040,1971? 160,1994 R62
Post Options Post Options   Thanks (0) Thanks(0)   Quote rms61moparman(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2024 at 8:31am
I looked on the website but couldn't find anything close.
Mike
ranger43 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ranger43 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2024 at 8:32am
I just got one for my 210.  Agco dealer had in stock.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2024 at 8:45am
totally different boot. Looked it up. Appears discontinued. I know I paid 75 for it a year ago.
ryan
AcFordHawk View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote AcFordHawk Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2024 at 10:55am
Check on Tractorhouse.   See there are some listings for the part # - 72072519.  Probably need to call to verify stock on hand.  One listing from Lindstrom shows 40 on hand.
IB (restoring), MF GC1705, MF 2705E
Post Options Post Options   Thanks (0) Thanks(0)   Quote rms61moparman(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2024 at 4:04pm
I e-mailed Linstrom and although they didn't have it, they sent me a list of dealers who had it listed in their inventory. (sure wish I could get connected to that gateway)
Luckily, the dealer right here in Columbia, Ky. had one and it is now on the way!!!
Lightened my wallet CONSIDERABLY, but as stated above, still better than a transmission and hydraulics full of water.
Thank you all for your help with this issue!
Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote rms61moparman(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2024 at 5:30pm
I'll say one thing for the people at AGREVOLUTION LLC, they are on the ball with their parts service.
I ordered this boot on 3-18-24 at about 10:00am, and it was on my door by 3:00pm today 3-19-24!!!
That fact alone will make me try to do business with them again.
I have lots of Allis stuff needing parts.
Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2024 at 8:48am
Good to hear you got one.
On a similar note I called the Farm Store and talked to ReedE yesterday. They had a boot for the 6080 in stock. It's here now just waiting on me to get it put on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2024 at 8:55am
I'll post this here as opposed to starting a new thread.
Had a little time yesterday afternoon before heading to work. Worked on D-17-1 a little with mixed results. Looking for a change of pace, let's change that shifter boot on the 6080. Pretty simple job, 6 screws and 2 knobs to remove. I put a drop of 'low strength' loctite on the knob threads as the gear shifter likes to get loose. Anyway, took a couple pictures, before/after.
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2024 at 11:42am
Looks good!
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2024 at 9:54am
Thanks.
GSTROM99 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GSTROM99 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2024 at 10:14am
You should've said "after/before" pics.  I spent a minute looking at the first ("before") pic, thinking that didn't look too bad at all.  Then I saw the second pic...  Smile
Nice job.  I think my D-17 needs one too, but it doesn't spend time in the rain.
Edited by GSTROM99 - 22 Mar 2024 at 10:15am
Post Options Post Options   Thanks (0) Thanks(0)   Quote rms61moparman(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2024 at 10:33am
They are cheap and easy for a D-17.
Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote GSTROM99 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2024 at 4:00pm
My local AGCO dealer (10 miles away) had the D-17 shift boot in stock.  Exact replacement - even has the two X's.  Hardest part was getting the knob pulled off.
Edited by GSTROM99 - 22 Mar 2024 at 4:02pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2024 at 10:02pm
Brenda at SLI has them, they are expensive! If I remember correctly from last year $95. I took slip joint pliers and bent my shift gate tabs up some to prevent it from tearing the new boot. That really helps. Just my 2 cents
Post Options Post Options   Thanks (0) Thanks(0)   Quote rms61moparman(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2024 at 11:45pm
I'm thinking about making a cover for the boot out of an old inner tube.
I don't want the U/V rays getting to that expensive little rascal!
Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2024 at 7:18am
Ya got me! Maybe I should have edited the text?
Edited by IBWD MIke - 23 Mar 2024 at 7:18am
eireog68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eireog68 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2024 at 3:24pm
i need one also did you get one and if so where and how much?
Post Options Post Options   Thanks (0) Thanks(0)   Quote rms61moparman(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2024 at 6:26am
I located one from the Agco dealer in Columbia Ky.
With shipping, it was around 100 bucks.
Yes, it is outrageous, but cheaper than a transmission oil change these days.
Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2024 at 7:04am
While talking to Alex Saturday at Amana, I spotted a boot for a 6080. He said I was the only guy to pick it up. Told him I just replaced mine and didn't foresee needing another. He always seem to come up with some interesting stuff. Glad he makes the trip to Iowa.
