IB fenders |
Freewheeling ![]() Bronze Level ![]() ![]() Joined: 05 Nov 2017 Location: Wisconsin Points: 170 |
![]() ![]() ![]() ![]() ![]() Posted: 12 Jun 2024 at 6:40am |
I need to replace the left fender on my IB. I've seen posts that say the WD fender is the same except it needs a couple holes for the center plate. Others say that they fit but are not the same because the leading edge is different. Has anyone compared the two side by side? I'm using the stock right side and want them to look the same. Also what has your experience been with the quality of the aftermarket WD fenders? At least one supplier states they are not restoration quality. I assume there is only one manufacturer.
Thanks y'all.
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 88105 |
I bought a used pair of WD fenders 15 years ago at a farm sale.. The "stamping" is the same as the IB... There are a couple extra holes to drill or plug as they mount a little different.. The basic fender came off the same steel press.
being in Wisc, your in the same general area as LON(Mn) .... i would guess he has a few fenders.. as compared to aftermarket.
Steve in NJ ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Andover, NJ Points: 12007 |
Years back when I had my IB, I used WD fenders as well. They needed
quite a bit of work to make em' fit nice. I'm not a body man so I had
my body guy change em' over for me. He had to weld in the center plate,
fill some of the WD holes and drill some new holes. I gave him the old
IB fenders to use as patterns and to take measurements off of them. They
came out nice, but they weren't a "drop on". ![]() |
