D-17 High Crop Diesel |
Mauldin1 ![]() Bronze Level ![]() ![]() Joined: 09 Jun 2024 Location: Alabama Points: 5 |
![]() ![]() ![]() ![]() ![]() Posted: 09 Jun 2024 at 1:37pm |
I own a D17, single front wheel, high crop with the 6 cylinder N/A diesel. How rare is this tractor? Have only found a few pictures online with the single wheel high crop and they only had gas engines.
omahagreg ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: Omaha, Nebraska Points: 2800 |
Not sure how rare. Dad took a picture of a D17 hi crop single front wheel propane near Beatrice NE several years ago!
Greg Kroeker
1950 WD with wide front and Freeman trip loader |
Mikez ![]() Orange Level Access ![]() ![]() Joined: 16 Jan 2013 Location: Usa Points: 8209 |
Welcome to the forum.
Would have to see more pictures. The front single wheel doesn’t look high crop. Hopefully some of the other gentlemen that have more knowledge on high crops will chime in
RedHeeler79 ![]() Bronze Level ![]() Joined: 09 Sep 2023 Location: NE Kansas Points: 99 |
According to Swinford’s book, only about 40 single front wheel diesels were made in 58-59, and no other numbers shown for the later years. The grille, oval muffler, lights on fenders, etc appear to be series 3 or newer. Maybe someone converted it to its present configuration. Who knows? Please provide the serial number for the tractor. Would definitely tell more of the story.
Edited by RedHeeler79 - 09 Jun 2024 at 10:19pm |
This is the only picture I have right now. Will have to cut the briar patch down to get to the serial number. My daughter was wanting to start going to tractor shows and i thought this would be something different from the John Deere and Farmall crowds.
We are the second owner of it. The original owner had it set up with the spray boom and all for cotton and corn. I thought the drop boxes on the rear axle housing is what considered it to be a high crop.
Gary ![]() Orange Level Access ![]() Joined: 13 Sep 2009 Location: Peterborough,On Points: 5224 |
Similar D-17 Diesel High Crop posted on the Forum in 2012. Was located in Phoenix, AZ G https://www.allischalmers.com/forum/d-17-single-front-wheel-high-crop-d_topic54839.html |
TramwayGuy ![]() Orange Level Access ![]() Joined: 19 Jan 2010 Location: Northern NY Points: 11319 |
“... I thought the drop boxes on the rear axle housing is what considered it to be a high crop.”
All D17s had drop boxes on the rear axles. |
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7263 |
I don't think it's a factory high crop. Looks like someone just put taller wheels on the back of a regular D17 and called it a high crop.
That’s what I was thinking dseries.
But no matter what it is I like your idea of daughter taking to tractor shows
Macon Rounds ![]() Orange Level ![]() ![]() Joined: 18 Feb 2010 Location: Pittsburgh Pa Points: 2105 |
Looking at this photo, several things stand out..
The hydraulic leaver is on the steering column with light on fenders and oval muffler. Makes it a series III... It could have originally been a high crop with longer final drop housings. As the fenders are located much higher from the tire than a standard row crop ...... The photo I have included is a standard row crop D17 IV tractor with 38" rear and a 16" front . ![]() Edited by Macon Rounds - 11 Jun 2024 at 9:39am |
Macon brings up a good point with the fenders. Or is it an allusion and tires spaced out far away.
Edited by Mikez - 11 Jun 2024 at 7:15pm |
It's wide and tall
BILLP-SE-MI ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: SE Michigan Points: 681 |
here is my WD SFW High Crop ![]() |
have a few other sfw's also ![]() |
SFW WC
SFW RC |
On your D17 it has the standard fork, hc forks were extended 3 inches. for the solid cast wheel 9-10 tire or the spoke type wheel 7.50 -16 tire.the rear wheels would be 38 in spin outs. have a good one Bill P
MikeZ
Brings up a good point... I believe the the fenders only look like there higher in regard to the rear tires. Due to the wide wheel spacing and photo angle.... So it is a standard row crop tractor with 38" rear and SFW. These tractors are referred to as high clearance tractors... |
These three tractors are all configured as high clearance...
HudCo ![]() Orange Level ![]() ![]() Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3363 |
the d17 series 1 diesel parts tractor that i have has taller fender mountsabout 4 inches higher than my other d17d it all looks the same except every thing is just taller
AC720Man ![]() Orange Level ![]() ![]() Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 4773 |
Nice looking tractors everyone. Neat to see some single front wheel tractors, don’t see those often. Bill that’s a nice collection that you have, did you do the restorations?
Rob |
Rob. If they needed any repair I did the work, painted them also. for got to add my WD45 sfw in work clothes. ![]() |
