Allis Chalmers D15 Series II Power Steering Hose |
daxlw
Bronze Level Joined: 16 Jul 2013 Location: IA Points: 9 |
Posted: 06 Jun 2024 at 8:16am |
Anyone know where or how to fix the high pressure side of the power steering hose? Developed a crack in mine and its been a trying time to find a replacement.
AC720Man
Orange Level Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 4773 |
We had to have a local hydraulic shop repair ours.
DSeries4
Orange Level Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7263 |
Have you tried AGCO?
daxlw
Ive checked with AW, Stiner, Inline, and AGCO, but they dont have any. Part #70233483. May have to use compression fittings or find used somewhere. Thanks.
PaulB
Orange Level Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 4502 |
I would take it off and send it to "INLINE TUBE" to have it copied. I'm sure that they don't have in ready to go or even in their listings. I had a local shop make some for me a few years ago, although it did fit at each end, it looked nothing like the original.
Steve in NJ
Orange Level Access Joined: 12 Sep 2009 Location: Andover, NJ Points: 11631 |
Dax, I sent you a PM. Steve@B&B
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 78781 |
Your local NAPA store might make hoses.. take the original to COPY.
RedHeeler79
Bronze Level Joined: 09 Sep 2023 Location: NE Kansas Points: 99 |
I’ve had decent luck brazing steel tubes, if it’s just a small crack or area needing repaired. Not sure how heavy-walled the p/s tubes are, but the hydraulic lines are substantial and easy to braze
AC720Man
They are NLA so that’s why we had to have ours repaired. Normally we would just order one from SLI and know that it’s OEM.
Mikez
Orange Level Access Joined: 16 Jan 2013 Location: Usa Points: 8211 |
I don’t have it ether.
Marlyn nwia
Silver Level Access Joined: 11 Sep 2009 Points: 374 |
Hydraulic Solutions Sheldon, Iowa take the old one to them:
you will be impressed what they can do!
daxlw
For a quick fix, I bought a 50 inch 3/8th brake line from AutoZone and bent it to specs. Ideally, you would want to get a 40 inch line, it would fit easier but I did not have that option. The ends were the same size as the old line. It does the job for now. If this did not work, I would have cut out a section of the line and used compression fittings to make the old ends work or shorten the new breakline.
