I promised you guys pics |
Author | ||
LouSWPA ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Clinton, Pa Points: 24091 |
![]() ![]() ![]() ![]() ![]() Posted: 20 May 2024 at 7:18pm |
of my cars awhile back. Here is two of the three. I took pic of the third one, but they didn't come out.
Here is the 1923 23-35, and the '31 ![]() ![]() ![]() |
I am still confident of this;
Sponsored Links | ||
The third is a '29 two door Coupe with rumble seat and golf bag door. I'll get pics soon. Problem is it is in a storage facility, and it is very dark in there and no lights.
All Buicks Edited by LouSWPA - 20 May 2024 at 7:22pm |
Thad in AR. ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Arkansas Points: 9319 |
Very nice
ACinSC ![]() Orange Level ![]() Joined: 16 Dec 2015 Location: South Carolina Points: 2633 |
I agree, very nice!!
jdeere562 ![]() Bronze Level ![]() Joined: 02 Oct 2023 Location: SW Iowa Points: 24 |
Nice little collection of old cars!
NEVER green ![]() Orange Level Access ![]() Joined: 28 Feb 2013 Location: MN. Points: 6721 |
Very rare to see an old Buick, let alone three.
My family is threatening to have me medically evaluated!
The blue one, the 1923, as near as I can tell, is basically original. The odometer says 30K miles, but the wear on the peddles suggests probably 130k, so I don't know. Anyhow, I like the 'Grapes of Wrath' look so my intention is to preserve, not restoration. Clean it and maintain it from further deterioration. Not sure yet, how I am going to accomplish that. Suggestions are welcome. This car is probably going to be serving parade duty and trailered to such events, as well as static shows. My main interest here if for the youth see what a 100+ year old car looks like. BTW, that car was manufactured with rear brakes only! It uses a drum with a band around the outside for service brakes, with a shoe brake on the inside for a parking/emergency brake. On this car, the parking brake is nonexistent! for some reason previous owner found it necessary to remove it. I got lucky and found a derelict that was rotting into the ground that the owner was happy to get out of his yard at a reasonable price. The brake parts are there and appear to be useable. This was fortunate because parts for these cars are unobtanium! The black one, the '31 is the recipient of a sloppy restoration sometime in its life. Looks good from 50 feet, but lots of blemishes in the paint up close. A lot of 'sins' were simply painted over. On top of that, there are plenty of 'hanger rash' in addition to the sloppy paint prep. Dents, chipped paint, etc. It also needs a little engine work, smokes, and has some noise that suggests possibly a little rod knock. Also, the clutch peddle comes almost all the way up before it actually engages but does engage smooth and does not slip. And the brakes need adjusted. four-wheel mechanical brakes, and right now I think only one wheel is actually working. Interior is pretty good, not perfect, but OK. No restoration on this one either, just address the mechanical issues and drive it. The '29 is currently a non-runner. Previous owner started to disassemble it for unknown reason. The interior is pretty good, and from a distance the outside looks good. It was painted in 1986, pic of the paint job at the time of the work was included with the car. However, for whatever reason the paint crazed, cracked and is chipping off in large chunks. So this one will require repainting. I'll get pics as soon as I can. Unlike Ford model 'T's and 'A's are easy to support, there are parts readily available. But not so for most other makes and models. Part of the challenge and fun for these cars is the parts chase.
dp7000 ![]() Bronze Level ![]() ![]() Joined: 26 Sep 2021 Location: Winchester Kent Points: 137 |
Very nice to see. Thanks for sharing.
Maybe you should check out Hemmings Motor News and see what parts are out there. |
DMiller ![]() Orange Level Access ![]() Joined: 14 Sep 2009 Location: Hermann, Mo Points: 29966 |
Very nice, as noted Hard to find Buicks of that era at all not to mention three together.
tadams(OH) ![]() Orange Level Access ![]() ![]() Joined: 17 Sep 2009 Location: Jeromesville, O Points: 9783 |
Yes, Very Nice
Steve M Ind ![]() Bronze Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Springport IN Points: 61 |
Nice cars there Lou. I just recently purchased a 1927 GMC 1 ton truck with the factory installed Buick 6 Cylinder in it. Motor is partly dis-assembled and I'm assuming stuck with all the rust on the cylinder walls. Can't wait to take possession and start tinkering with it. I might need some advice from you as I proceed.
Edited by LouSWPA - 22 May 2024 at 9:20am |
You got good advice already and I'll post a picture when I can.
Edited by LouSWPA - 22 May 2024 at 9:34am |
Tracy Martin TN ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10579 |
Really neat collection! Tracy
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 78667 |
LOu, has this been going on for some years, or did you get them all recently ? Sounds like a Retirement Job ??
![]() Where do you store them ? I see a cement block single bay double length stall ??
Edited by LouSWPA - 22 May 2024 at 10:17pm |
FloydKS ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: S E Kansas Points: 7989 |
one important factor is you are having fun.. whether it is orange or Buick, fun is important...
Are your cars equipped with wooden floors or metal? If wood, is it tongue and groove?
[QUOTE=Steve M Ind]Are your cars equipped with wooden floors or metal? If wood, is it tongue and groove? Yes, wood floors, and so far as I have taken note, no Tand G[/QUOTE]
Edited by LouSWPA - 23 May 2024 at 9:07am |
JW in MO ![]() Orange Level ![]() ![]() Joined: 16 Feb 2010 Location: South KC Area Points: 2598 |
Good looking group Lou. A feller gets real attached to them things and amazing what you'll spend on em too.
DaveKamp ![]() Orange Level Access ![]() ![]() Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 5655 |
The reason parts are hard to come by for high-midrange cars prior to 1930... like old Buicks, Hupmobiles, REOs, Essex-Terraplanes, Knights, Caddillacs, Chryslers, Auburns... Low production volumes- they were significantly more expensive than Ford Ts and As, Chevrolets etc, so economics challenged sales volume... that, in conjunction with higher parts quality, made the parts demands comparatively lower. As years passed, many of the older high-quality cars like your Buicks were run 'till they would run-no-more, and frequently, if the owner was still economically strong, would simply buy a new Buick, and send the old to junk. Many times, these 'survivors' got parked in carriage houses of second homes, and other times, they were turned into 'pickup trucks' for estate maintenance. Their heavier chassis and robust drivelines made them perfect for the kinds of things we'd use a 3/4t pickup for nowdays... so it'd not be unusual to see a Stoughton cab atop a Buick chassis, with a wooden stake bed, buried in the back of a collapsed barn. Nice collection Lou- as for the original one, they're only 'original' once. When a guy decides to strip off the original paint, after that, it's only a 'restoration'... so fix what needs fixed, and keep the rest original. As for the 'poor restoration', leave it that way, but keep 'em mechanically operable... and if you 'restore' one, make it your 'parade' machine. Mechanical brakes- that's actually 'anti-lock' brakes... one might hang up when you step on the pedal, but the rest are 'anti lock'...
Dave a PS to your explanation concerning parts availability. In addition to what you said, the Fords are more popular, and therefor there is a significant aftermarket for parts for them.
