Does anybody know
Model 70 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Model 70 Quote  Post ReplyReply Direct Link To This Post Topic: Does anybody know
    Posted: 22 May 2024 at 7:37am
Anything other than the check valve between the manifold and valve stack that causes the 3 point arms to settle on a D19. Thank you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2024 at 2:44pm
Leaking seals on the lift cylinders.
As my local John Deere dealer used to say about lift arms drifting down:  As long as you do not sleep under the cultivator, you will be fine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Model 70 Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2024 at 4:44pm
I will check out the cylinders,good point to not sleep under a cultivator 👍
This page was generated in 0.174 seconds.
