D17 series iv head cylinder |
waw1962 ![]() Bronze Level ![]() Joined: 11 May 2024 Location: PA Points: 13 |
![]() ![]() ![]() ![]() ![]() Posted: 11 May 2024 at 11:18am |
uploads/24759/d17_core_plug_2024-05-12_10-43-27.pdf
I've read alot about frost plugs, but when I look at the head from my D17 series 4, there are only two, and they are more like core plugs... not the button type pop in plugs shown and discussed. I can't find new ones online, as I'm in the process of putting a new head gasket it, thought I'd change those too. Any help on these plugs and why are they different than what I find online? Thanks.
Edit... the plugs I took out are about 1-1/2" by 1" and solid.
Edited by waw1962 - 12 May 2024 at 10:44am |
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 19734 |
AGCO dealership.
I looked at an AGCO page, pulled up the D17 head parts list. The "core plug" shown is not what I have. I flipped the head over, and drove the two plugs out of the top. They are solid pieces, 1-1/2" long, 1" diameter. Could someone have rebuilt it before, and substituted a solid plug instead of the "cap" type shown? I tried to include a picture, but can't get it down to the 2mb size limit. Thank you, Dr Allis.
Didn't come from West Allis with anything like that in it.
I'm wondering if I can replace with standard freeze plugs? Not sure why these were in the head. Correct me if I'm wrong, but there should only be two in a 1968 D17 Series IV, yes? Thanks again.
Mikez ![]() Orange Level Access ![]() ![]() Joined: 16 Jan 2013 Location: Usa Points: 8202 |
Are you looking for #5 ![]() |
Yes, but curious about the plugs I pulled out.
Alex09(WI) ![]() Orange Level ![]() ![]() Joined: 15 Mar 2012 Location: CECIL WI Points: 1699 |
Those are not replaceable core plugs. They are permanent plugs not mean to be removed. All D17 cylinder I have seen, have that style. They can be identified by a tapered bottom towards the center and are solid steel. Not flat bottom like replaceble core plugs.
www.awtractor.com
Well crap.... now what? Clean them and the bore up and put them back? Haven't done this before, in case you hadn't guessed. And I'm guessing, being permanent, very slim chance of ever leaking? I am taking it to a machine shop this week, maybe they can save me. Thank you.
Edited by waw1962 - 14 May 2024 at 6:57pm |
When looked up 230357 it shows the plug. Alex is it pressed in. ![]() |
looks pretty close to the plug in my post... I haven't found any new ones online.
Do you need the two.
I do need both. No sense in having the head reworked and then not install new plugs. Thanks.
Gatz in NE ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Lincoln, NE Points: 1034 |
[QUOTE=Mikez]
When looked up 230357 it shows the plug. Alex is it pressed in. ![]() That looks suspiciously like a Power Cell
