185 allis chalmers |
rickymotorbrains
Joined: 25 Jan 2019 Location: dry ridge ky Points: 56 |
Topic: 185 allis chalmersPosted: 27 Apr 2024 at 11:20am |
does anyone no where i can find a oil pan for the 185 that the oil pump runs on crank the newer stile motor
Lynn Marshall
Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2494 |
Posted: 29 Apr 2024 at 1:26pm |
I think that I have a couple of those, but the freight from iowa might be a killer.
rickymotorbrains
Posted: 29 Apr 2024 at 2:52pm |
how much would you want for one
rickymotorbrains
Posted: 01 May 2024 at 9:37pm |
did you get my message
I M Fedup
Joined: 01 Jul 2020 Location: Winchester Ky Points: 30 |
Posted: 01 May 2024 at 10:32pm |
I recall a few years back I made a few trips up to Dry Ridge. I remember a farm out on Highway 36 near Jonesville. There must have been a couple dozen or more older AC tractors scattered all over the property. Various models from WD up into the 190 style. You wouldn't be familiar with that place would you?
Posted: 02 May 2024 at 6:29am |
I am a fortunate individual. If I drive no more than 2 hrs from my house, I can take advantage of SIX salvage yards for old tractor parts. I can't imagine places around the country that don't have anything ??????????
Lynn Marshall
Posted: 02 May 2024 at 7:44am |
Sorry for the delay in response. I've had a few other things come up recently. I'd take $20.00 for the pan. I need to get it out of storage to be sure it's correct. I think that there were only two pans for the 180-185, depending on the oil pump location. Mine might have been off of a combine engine, that had a crank driven oil pump, but I'm not sure if it's different than the tractor pan. Will check.
Lynn Marshall
Posted: 02 May 2024 at 10:51am |
The pan that I have is a #4023964. It is off of a gleaner L or M combine. The only difference, from a tractor pan,that I see is that it doesn't have a drain plug in the bottom. It has drain plugs on each side. That would make it a little messy when draining oil in a tractor because of the front end wishbone.
Edited by Lynn Marshall - 02 May 2024 at 10:52am |
rickymotorbrains
Posted: 04 May 2024 at 10:01pm |
cant find any that has the oil pan for the motor that has the crank driven oil pump all have the old style
rickymotorbrains
Posted: 09 May 2024 at 8:20am |
did you ever get the pan out and look at it
Lynn Marshall
Posted: 09 May 2024 at 10:52am |
Yes. I've actually got two of them,but as I said, they are both off of combine engines. They have the drain plugs in a different location than the tractor application. I also have one of the cam driven oil pump pans too. I can send you pictures if you want.
rickymotorbrains
Posted: 09 May 2024 at 12:57pm |
can you send me pic of the oil pan
rickymotorbrains
Posted: 09 May 2024 at 6:31pm |
ok i dont mind the drain holes being different as long as it fits on the motor
automaticdave
Joined: 20 Jan 2011 Location: Granton, ON Points: 261 |
Posted: 10 May 2024 at 6:53am |
I,m seeing on AGCO parts that a late 185 Crank driven oil pump PAN is the same as a 7000 # 74024125, correct me if I,m wrong. Dave
rickymotorbrains
Posted: 13 May 2024 at 1:18pm |
do you no where i could find one
rickymotorbrains
Posted: 13 May 2024 at 1:19pm |
where you live or can you give me some junkyard names to try
automaticdave
Posted: 14 May 2024 at 9:49am |
rickymotor, I have a oil pan off of a burgandy 7000 but I,m in ontario
rickymotorbrains
Posted: 14 May 2024 at 10:43am |
How much you want for it and could you send pic
orangereborn
Posted: 17 May 2024 at 8:36am |
I have a parts maroon belly that has the pan on it. After planting I will be coming to Nashville Indianapolis and Ohio if that would help. Thanks. Dale
