Wanted D-17 Battery Parts
Michael (WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael (WI) Quote  Post ReplyReply Direct Link To This Post Topic: Wanted D-17 Battery Parts
    Posted: 03 May 2024 at 3:13pm
I am in search of a good used battery tray, battery hold down clamp and J hooks for a D-17 with a gas engine.  I am located in northeast Wisconsin so if it is not located locally it would need to be shipped.
BigGuy1000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BigGuy1000 Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2024 at 6:46pm
You can still buy the NOCO brand battery holddown and J hooks (for AC 170gas if same) at Farm and Fleet, Tractor supply, etc.  NOCO no longer has the larger size holddown and J hooks, for a larger battery on other tractors.
ValleyFarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ValleyFarm Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2024 at 7:19pm
Hi Mike. Check with Wisconsin tractor parts in Black Creek. They may be able to find you a used one. Or if your good with a welder. You could have a fab shop make you a tray and cut the old one off and weld the new one one. I've also seen them new running around on different websites. Hope this helps.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2024 at 8:14pm
There are different trays for different series. I know the Series 4 is different than Series 1 or 2. Not sure about Series 3.
The tray for a Series 4 are hard to find.
Travis(NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2024 at 9:01am
Reproduction battery trays are or were available.  I believe A&W Tractor or DJ's Tractor parts offers them.  There are two styles that I am aware of, the early style is for the oil bath air cleaner used on the series 1 and 2 and the second is for the dry filter used on the series 3 and 4.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2024 at 6:58pm
Bill Deppe/AC Salvag View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Deppe/AC Salvag Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2024 at 10:58pm
Have reproduction trays available for early D17.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2024 at 1:33pm
According to what I have seen, Series 1, 2 and 3 took the same tray. Series 4 were different.
