hd6g Right Side Has No Drive |
Hammer Down
Bronze Level Joined: 22 Apr 2024 Location: Weiser Id Points: 11 |
Posted: 25 Apr 2024 at 10:13am |
I just purchased a HD6g Track Loader but made a big mistake on not insisting they let me test drive. The owner operated it and made it look like it worked ok. To be honest I didn't pay attention good enough because I was trying to catch his Weiner dog to prevent it from getting run over. Engine and hydraulics work great. They said it needed some brake work. In my research it looks like adjusting the brakes or replacement is relatively simple. The brake pedals both go to the floor. I figured I would fix it, so I bought it. When I had it delivered I found the right side has no drive. When I pull the left steer clutch and push the brake it makes a noise from the right side but doesn't move. When applying the right brake in reverse it turns sharp left. Question is what is broken in the right side and how difficult is the repair? I do like it because it has a bucket, HD forks and a winch.
CAL(KS)
Orange Level Joined: 18 Sep 2009 Location: Chapman, KS Points: 3746 |
either you have broken gears in final drive, the sprocket shaft is broken, or the steering clutch is stuck open/teeth sheared. failed bearings could lead to broken teeth. be advised sprocket shafts are different splines between early and late machines. the seals basically cant be replaced so take care when removing installing etc. doable by the shade tree mechanic with basic tools, and lifting capability. the loaders are more difficult to work on than the dozers though. do some more investigating before you tear into it and get a service and or part manual. Also General Gear is a good salvage yard located in ID can likely supply parts.
Edited by CAL(KS) - 25 Apr 2024 at 11:22am |
gemdozer
You need to check by the inspection plate under the seat right side if every think is turning when you angaged the left side stering cluch and if he turning it is the final drive probleme ot broken top pinion
Hammer Down
Are you saying the clutch plate teeth can shear off?
Les Kerf
Orange Level Joined: 08 May 2020 Location: Idaho Points: 649 |
At this point anything is possible. Pulling the brake/steering clutch cover as mentioned above is the best place to see if the trouble is upstream or downstream.
Coke-in-MN
Orange Level Access Joined: 12 Sep 2009 Location: Afton MN Points: 41235 |
Final drives and clutches are same as HD 5 machines . Same rear casting and internals
Removing the covers over clutches should give some idea where to start looking .
Same as removing the cast cover below machine to inspect final drive bull gear , and any extra wear that shows up in sump pan . Rear uses 3 gears as power transmitting to axle shaft indexed onto final bull gear . |
Hammer Down
I will pull the covers as soon as I get a chance. Is the bull gear you are referring to the same as the bevel gear in the parts book? And are there 3 total gears or 3 on one side?
Ages Cat
Orange Level Joined: 12 Sep 2009 Location: Hutchinson, MN Points: 681 |
Sounds like a broken axle. Pretty common occurance. You should be able to run it agaist a ditch bank or loading dock and determine if both tracks will pull. Pulling left lever should deliver power to right track. If it does not pull, axle is probably sheared.
Curt Anderson
HD3, HD5B, HD6E, HD6AG,HD6B dozer, I-400, 615, 616,(2) 620, 720, ACP25 lift truck, 1956 D Special Grader, AC 540 loader, AC 655 crawler loader, AC #84 plow, Simplicity lawn tractors. |
Hammer Down
That's exactly what's going on. Are parts available and where?
Coke-in-MN
first reduction is from transmission output to bevel gear , ring and pinion shaft , next from ring gear is to clutch hub - from clutch hub to shaft containing a small straight tooth gear , this drives a intermediate gear , this drive the bull gear which the axle is attached to . Axle is spline fixed to drive sprocket .
Each section has bearings which support and keep clearances . Axle shaft has inboard bearing , outboard and a bearing housing on track frame that is a link belt special bearing . Other gears have timkin cone and cup bearings , clutch and brake drum assembly are bolted to flanges on each side of those parts. flanges are held to shafts with center bolt and have splined attachments . If you lift that side of machine and block up so track is free , you could rotate the track using a come along to observe if movement in clutch compartment is seen. Could be clutch discs , broken bolts on flanges , gears , or ? Until one pulls the cover off the clutch housing and inspects that area - to start with - it's all just guessing . The axle shaft is a heavy unit and breaking it seems unlikely . Just like it could be stripped sprocket splines - anything is possible . |
Hammer Down
Thank you for the detailed drive discription, it helps me get an overall picture of what might be going on.
Codger
Orange Level Joined: 23 Dec 2020 Location: Illinois Points: 1827 |
What is the serial number of your tractor?
Hammer Down
6-11049
Codger
I'll post up some photos later today. Are you sure that s/n is for the tractor and not the engine? IIRC the engines started with a 6, and serial number in the late 50's. Edited by Codger - 28 Apr 2024 at 3:00pm |
Hammer Down
I found another plate that says Tractor Serial No. HD6G-11126 So you are correct on the engine #. Thanks for your help. |
Codger
I'll send you some .pdf files for the tractor if you'll pm me an email address. No way to do this on the site I've found.
Hammer Down
Sent
Codger
Hopefully you find those useful.
DCRanch
Bronze Level Joined: 05 May 2024 Location: Helena Montana Points: 1 |
I had the same issue with my HD6G years ago. The problem was in the final drive, I think a broken shaft. Over the years I also had a lot of repair work. I was able to find any part I needed at: www.walterimplement.com 509.982.2644
They are in Odessa WA. Very good to work with, and reasonable prices and support, repair manual pages of parts, and some technical support. Good luck!
