AC 160 fuel leak |
FarmerJohn22
Bronze Level Joined: 05 Nov 2013 Location: Fall City, Wa Points: 74 |
Posted: 19 Apr 2024 at 1:44pm |
I recently purchased a 160 with the Perkins engine, and it is now leaking quite a bit of fuel out of one of the fittings on the injector pump feeding the cylinder. It is one in the back, and I can't seem to get a wrench on it. I've ordered a injector fuel line socket that I'm hoping will fit. I'm wondering if I should plan on replacing all the high pressure fuel lines, or I think there are gaskets in the fittings, would it be enough to replace those? I'm assuming a fuel line seal kit like this would work for the allis chalmers, even though it says it is for a Massey? Thanks for any help!
1953 CA, 1950 G, 1970 160
8070nc
Orange Level Access Joined: 21 Mar 2019 Location: North Carolina Points: 506 |
I wish I could help you. We had a 160 but that was 50 years ago. I was too young to know what kind of pump was on it. I hate for no one to answer you. Maybe some one wil chime in
1984 80780
DSeries4
Orange Level Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7341 |
First off, I don't know why you would want to replace all the high pressure lines. If they don't leak, leave them alone. I am assuming your leak is where the high pressure line connects to the back of the pump. There is no gasket there. There is a copper washer on each side of the fitting with a bolt going through it. Loosen off the bolt and then re-tighten it. If that doesn't work, replace the washers. I don't even know what a fuel injector socket looks like. I used a regular wrench on the lines on my 175. No problems.
FarmerJohn22
Well, turns out once I got a wrench that I could get on the fitting, it was an easy fix. Just tightened it up and it worked like a charm.
